I know your running out of space...... I am ready to unload that m80 for you.........Lol. Nice grabs.
:lmao::lmao::lmao::lmao: Not gunna happen...Yes I am running outta space..
Recieved M-70 today as well as Brutals T-7.
M-70 has a burnt up film cap in the power supply .... C607 .22uf/250vac
http://www.audiokarma.org/forums/showpost.php?p=1723037&postcount=1
Already e-mailed yamaha for the replacement part.
Or...
http://www.mouser.com/Search/Produc...Vvirtualkey66720000virtualkey667-ECQ-U2A224MV
will wait and see what Yamaha recommends..
Glad it made it OK.
It is a sweet tuner. Love the light intensity change on the dial indicator when you lock on a station.
I find myself torn between the T-7 and the T-1, but then I haven't rolled in the recapped T-2 yet.![]()
Notorious..No .But it does have a part that needs to be replaced in the primary power supply..A X2 suppression cap.The bulletin is primarily for EU units operating on 220V.This particular unit has a bad one as well.
Finally got a chance to look a little deeper and guess what .It started to intermittently mute. and now have a constant mute situation:scratch2: Going to swap out the LC chip this weekend.That IC will fail in the control of the two output muting transistors and set them into a pemanent MUTE state. I simply removed the resistor in that control lead and got output.
Well swapped out the 7200 chip------No more mute..but the preselect still does the same thing. Looks like its time for vintageaudiomanuals :thmbsp:Odd, I never had that issue, just the memory.
I think there's a cap in there I installed to replace one I thought was burnt/broken, but may just have been cut by the factory, don't recall if I took it back out. let's look up my old thread on that tuner.
well swapped out the 7200 chip------no more mute..but the preselect still does the same thing. Looks like its time for vintageaudiomanuals :thmbsp:
Interesting what you think of the M70. And what you do with it. Ive gopt one and its my main amp. Its not the end all be all. But it gets the job done. How much to do a C70 and M70 refurb?
:yes::yes::yes:Interesting what you think of the M70. And what you do with it. Ive gopt one and its my main amp. Its not the end all be all. But it gets the job done. How much to do a C70 and M70 refurb?
:yes:
I gots another recent purchase inbound . Yamaha M-65 Power Amp for 50 clams.Yes it has issues..
I'll be up next weekend to pick her up!
Thanks for fixing her up so quickly.............![]()
Atta boy! Nice shot.Can we expect a full report? with pics? on the M-70
I was the lucky bastard when I happened upon this M-70/C-2 pairing at the local thrift, hoping to sell the M-70 to pay for the preamplifier( I have 5 M-Series amplifiers already).
After listening to the pair i decided to oft a NAD amp/preamp and keep the Yammies.
The Yamaha combo sounds so good driving either a pair of ADS L-1530s(95db sensitivity) or my Infinity QLS-2's, running rather warm exactly like a M-50 I used to have, but basically running the same temperature at high or low volume levels... even in triple digit heat.
