Glenn here is my first try to explain it (in german English):
The tonearm mechanics is driven by an independent motor, wich is connected to it by a small belt.
(A really good turntable has a belt drive for the arm and direct drive for the platter ....
On my TT this belt has lost some part of it´s strain and was not able to transmit the torque, which is necessary to start arm movement.
The result was, that the motor ran all the time, but the belt slipped over about every second (click noise) and the platter brake electronics was activated all the time (hum of the plinth), even when the platter was spinning (additional wow and flutter, because of fight motor electronics against brake electronics).
When I cleaned the belt with some alcohol and increased the strain of it, the arm motor was able to execute the complete mechanical program to the end, the arm went back home and after that the motor stopped and the hum disappeared some seconds later ...
I also had to replace a dry capacitor in the strobe light generator. I would recommend to do that with your TT too, because the strobe light generator has a feedback to the XTAL-lock .. !
Quite a complicated beast, which doesn´t sound very good if anything goes wrong inside.
After these and some other repairs, the PS-8750 suddenly was extremely silent and all the click, hum and wow + flutter were gone ....
