Not sure if the base is covered in some ultra-thin layer of vinyl or melamine or if painted. The tags on this machine, one on the back of the base and the other in post #49, both feel off. Believe this was due to the moisture I alluded to in my previous post. When finished, I'll put them both back on once everything is running well.
One problem with this TT is the lack of access to the insides without turning it on its back. Then, of course, one can't reach the controls, the platter must be removed and the TA is not really in the optimum position to run correctly and be set. The neon bulb and CdS sensor for the automatic features of the TA movement have adjustments, as does most everything on this TT, so will start playing with them shortly. Have removed the base and letting it 'dry', in the event any moisture is left in there. Next step is some Deoxit.
Serial Number is 800579.
