SONY PS-X6 automatic functions
So turns out I blew q101 102 and 103. Also the 6v zener diode was burnt. Replaced all and now I got 14v on the adjustment point. Which is great. But still no automatic function. I think the solenoid doesn't have the power or something to move over the magnet to stop the motor. If I turn the tt on and press start the table starts spinning. But if I press it again to stop, it won't stop, led of the button does go out and readings in the flipflop transistors indicate a reset, so electronically it looks OK. Also auto return at the end of the record doesn't work. Checked the voltages on the return bulb mechanism and light resistor. They are fine. If I move the arm with the solenoid/magnet manualy the arm return function seems to work and the motor stops turning. Switch s3 has good readings and so do q401 - q408.
Any ideas?
Ahora soy yo quien no tiene los 14v , cuando al comprobar voltajes hice un puente"corto" (no puse cocodrilo a las pinzas del polimetro y ocurrió el pequeño desastre), placa bajo plato pin 25 (BLK) TOCO CON pin 24 (ORG Y RED), EL cable naranja"ORG " de esta placa está conectado al pin 21 de la placa de entrada voltaje , buscaré que elemento ha colapsado creo que ha podido ser la resistencia regulable RV101 ..., pues ahora tengo 17v y no puedo bajar el voltaje con la resistencia
So I measured the voltages going to the solenoid. When not playing it says 25.6v when not playing it says 23.3v. Isnt this gap to little to move the magnet? What transistors flip the solenoid and what voltages should they read during movement of the magnet arm?
Checked all the arms and plastic parts they are all intact.
Q407, al conectarse energiza el selenoide , no puedo medir el voltaje pues no he encontrado que he roto con el cortocircuito, todo indicaba que el daño se produjo RV101 pero lo he cambiado y sigue igual, ahora toca comprobar todos los Q101 -105
Holaaaa ya tengo los 14v .....al final después de comprobar he cambiado Q102 y Q103 me estaban fallando, he dejado encendido el equipo para regular y estabilizar los 14v, ahora mido el selenoide para comprobar los voltajes
_el pin 24 rojo naranja "es donde hice el cortocircuito jjjjjjjjj"(estoy colocando pinzas con sumo cuidado ⚠️ jjjj, el negro pin 44, lo he medido sin activar el selenoide y da 0,0mv (tu tienes 25,6v
Ah nice you found it. So you say when the solenoid is inactive it should measure 0volt. When you activate it, what does it measure? Could this mean q407 is broken?
_ el + rojo RED conecta en el punto donde hice el cortocircuito en mi placa con el cable naranja ORG, el - negro BLK , estos son los cables selenoide
-Q407 conduce a masa para cerrar el circuito , estás imágenes indican cuando el Q407 energiza el selenoide para activar retorno del brazo
_en está acción el Q407 energiza el selenoide para la función start automática para mover el brazo
_las funciones automáticas start/stop y la de repetición hacen que Q407 active y desactive el selenoide
También cuando llega al final disco
todo indica que Q407 puede estar fallando,
So new problem. I burnt through two vr401 resistors. Can't get the voltage of the lamp down to 11.5 volts without burning the resistor. The 6v zener and 120 ohm 2 watt resistor are fine. Diodes 419 20 and 21 I have changed. Making me crazy haha.
_Ostras, al bajar el voltaje se quema...,
La R449 10k, R450 10k, R451 10k pueden estar fuera de rango??
* tenemos del transformador los 24v que llegan de la salida condensador C103 rectificados y hay que reducirlos para la lámpara PL1 de 6v
_Diodo D416 entran 24v salen 18v,
_Q421 en la salida emisor hay 12v y en la base 11.5v
_Q420 en la salida emisor hay 11.5v y en la base 11v
_Q419 emisor 18v colector 11v en la base 17.5v
La R448 lado lámpara 20v y del lado transistor Q421 en su emisor 12v
<Al usar el traductor puedo leer : cambié los diodos 419, 20 y 21>, entiendo que te refieres a los [transistores Q419 ,Q420 y Q421]
_Comprobar los voltajes *Condensador C103
*Transistor Q419,Q420,Q421
*Residencia R448,R449,R450,R451
_no he dicho nada nuevo, aquí estamos en una situación similar a la que hemos tenido con (Rv101), tenemos los componentes encargados de hacer el trabajo localizados por eso te comento el comprobar los voltajes y entonces vamos descartado componentes
_no te vuelvas loco , cuando hice el cortocircuito en la placa comprobé las resistencias y el diodo desoldando una pata de cada uno pues tenía lecturas fuera de rango , comprobé la resistencia Rv101 <4.7k> pues las lecturas en comparación con Rv202 <4.7k > y Rv203 <4.7k> (según manual de servicio las RV101, Rv202 y Rv203 son de 4.7k "iguales") ,eran muy diferentes no lo entiendo pues entre Rv202 y Rv203 si tenía medidas equivalentes entre ambas y los transistores Q101,Q102, Q103 los comprobé con el multímetro y me daban los 6v en colector y en emisor, en este punto me estaba volviendo loco tal como tú dices y resulta que las pilas del polimetro "multímetro" estaban un poco bajas y al medir diodos pues jjjj entonces después de salir un día a comprar la RV 101 montar en la placa y ver que todo estaba igual volver a salir otro día comprar Q101 montar placa y ver que todo estaba igual, aquí me tiraba de los pelos y estaba volviendo loco pero en ese momento vi que el polimetro "multímetro" se apagó ...., entonces ummmmm , le cambio las pilas y cuál es mi sorpresa que al comprobar Rv101 y Q101 estaban bien y al volver a medir Q102 el emisor marcaba 0v y el Q103 el colector marcaba 3v , entonces salí otra vez a comprar Q102 ,Q103 y al montar en placa todo volvió a funcionar regulando los 14v en RV 101,
_De todo esto he sacado 2 piezas de recambio y 3 días de dar vueltas a la cabeza y tirar de los pelos (pues yo cause la avería haciendo un corto), y todo era las pilas del polimetro "multímetro" y los Diodos no se cómo la 1ª vez estaban correctos y al 3º día estaban mal
_Por eso te digo no te vuelvas loco pues tienes localizados todos los componentes encargados de la regulación de la lámpara 6v PL1, vuelve a comprobar los voltajes ya descartar componentes
*Muchas veces tenemos la cabeza en otro lugar y pasamos por alto las cosas más sencillas y fáciles, en mi caso me costó salir a comprar 3 veces al comprobar los componentes montados en la placa que está bien echo pero no comprobé los voltajes según manual de servicio por eso en el mensaje anterior me he extendido un poco con los voltajes
I have checked all the parts that regulate the 6v lamp, and they test good, but when I put in a variable resistor at rv401 it burns. I don't understand why.
I think I do understand why. I think the light is broken, it's drawing a lot of current burning my variable resistor and zener diode which is in series. So I'm gonna change the bulb and see where we're at.
_Quita la bombilla pones polimetro "multímetro" en serie en amperios y miras el consumo que tiene, aparte de los componentes que hemos hablado el consumo tiene que dar 0,0mA.... Al no tener carga
dejando el polimetro en Amperios y mirando el consumo según carga, la bombilla de 6v tiene una carga de 100mA, al quemar la Rv401 el consumo en amperios tiene que ser muy superior,
pones unos cables aéreos y conectas el violeta VIO al cable negro - del polimetro y lo dejamos puesto en Amperios y el rojo + del polimetro a la lámpara el otro cable blanco raya azul WHT/BLU al otro lado de la lámpara ,
** total que lo que hacemos es conectar el polimetro "multímetro" en serie en escala Amperios con uno de los cables y este a la lámpara y el otro cable a la lámpara y al encender vemos su consumo en amperios que es la escala que pondremos ( lo dejo para quien pueda interesar de como medir los consumos)
_ En la fotografía el pin 1⁰ ( WHT/BLU) contando de derecha a izquierda Y el pin 3⁰ (VIO)
_creo que he duplicado alguna foto , los terminales pin 21 naranja ORG y 22 violeta (VIO) de la placa donde está Rv101 solo el pin n⁰ 22 alimenta la bombilla desde el transformador con 24v, por esto te comenta el tema del condensador C103 (2200mf 32v)
** Estoy escribiendo y dando vueltas a la cabeza el pin n⁰21 de la placa de voltaje donde esta la Rv101 ,alimenta al selenoide ......(Te lo comento pues el pin n⁰21 y el pin n⁰22 están en el mismo zócalo y comentaste que el selenoide siempre tiene alimentación y estábamos culpando Q407 , no tendrás algún resto de soldadura suciedad o algo que algo contacto con estos terminales ....y al comunicarte te quema la Rv401 ya su vez alimenta el selenoide " solo por quitar elementos que puedan producir el fallo
Creo que entiendo por qué. Creo que la luz está rota, está consumiendo mucha corriente y quemando mi resistencia variable y el diodo Zener que están en serie. Así que voy a cambiar la bombilla y ver cómo estamos.
_comprueba cambiando la bombilla y si persiste comprueba el consumo en Amperios,
_Al intentar trasladar el máximo de información para poder contrastarla con la tuya me he extendido un poco lo siento, intentando ser lo más directo y simplificando pero a la vez dejando una información para futuras búsquedas en este tipo de fallos para usuarios que desconocen a la hora de interpretar lo que podemos estar diciendo, esto mismo pero a la inversa me ocurre cuando usuarios con un nivel técnico superior a mis conocimientos exponen y debaten sobre estos mismos temas y desde aquí les pido disculpas cuando me pierdo un poco y pregunto .
_GRACIAS POR EXPONER Y EXPLICAR COMO CORREGIR, REPARAR Y COMPRENDER EL FUNCIONAMIENTO DE NUESTROS EQUIPOS _
_GRACIAS A TODOS POR VUESTRO GRANITO DE ARENA _
Emitter of q421 is 17.5v and base 18, emmiter and base of q420 are 18v. These are way of. So maybe r450 is dead? I'm gonna check. Lamp is not lighting up. Only when I short the base and collector of q421, but then the 2 watt resistor gets super hot.
