It is possible to measure the bias current by measuring the voltage between the cases of any one J18 and K60 in a channel, on either a 4650 or 5650 amp. Unlike the Sony prescribed measurement (*) which measures the voltage generated by the bias current on one of the drain resistors, the case to case method measures on both, so it shows twice the value for the same bias current. The case to case method is fairly simple as the VFETs are accessible from below, but one still needs to be careful not to have a probe slip and short something!
(*) there are a number of problems with this method, including the possibility of bad contacts in the speaker selector, protection relay, or speaker connection. In this case people may observe no voltage and inadvertently end up increasing the bias current to danger levels without even knowing it.
