Straightening a bent TT a tonearm?
+1, those bearings took a shot.
Up and down is OK but, the horizontal bearings are binding or tight.:tears:
I need to open it up just to see what the problem is.:scratch2:
Oh well, the cart was worth the price. Maybe a new complete tonearm?
Thanks for the help.
John.:music::D
is that arm something special?
Hi,
It is a full automatic TT with regular tonearm, something is binding, the travel is smooth just not as free as it should be. The cuing stand is broken too. I have some parts in a box, maybe I can fix this.:scratch2:
Thanks,
John.:music::D
Ouch. That looks pretty bad. I know you'll get it working though John. That tt looks nice. Im sure its worth the effort. Good luck.
Looking at the way that arm is bent I can't help but have concern for the arm pivot bearings. Would have been under some kinda stress.
It looks like it was struck from above, or something fell on it.
Cartridge is good, so it was not playing when this happened.
Thanks,
John.:music::D
there are a ton of Technics 1200 arms on the 'Bay for cheap enough. I'd pop it out and install another - make it all manual and go :)
Or, turn it into an RCM :scratch2:
Who (or what) has done that to the arm? It looks bad and I think everything would be out of true (VTA etc). Don't know what to think about it really.:no:
Melofelo, I'm with you on this one!:yes:
Sad to say, but...
Thanks, I like the Heavy platter. I may just put another tonearm on it.
All Metal plinth too.
Thanks,
John.:music::D
I have a box of tonearm parts, and I think there is a Technics one in there.
You know how I love a challenge, the electronics work, platter, speed, Etc.
Thanks,
John.:music::D
Nice picture,LOL.
I don't give up that easy, I have the time, and would like to see it working.
It has a nice solid platter too.
Thanks for your support.
John.:music::D
Well, you certainly have the right attitude. The tonearm wand can be replaced, I was concerned with what you said about the horizontal movement. Good luck.
That is a good looking platter.
Thank you, I am finishing a RT-6506 Cassette deck now and should have it on the bench later today. Can't wait to open it up.
Thanks,
John.:music::D
One thing no one has mentioned: You need to support that arm from the INSIDE when working on straightening it, just as you would when bending it. That means removing it, plugging one end and filling it with fine sand. Then plug the other end. The sand inside will help prevent it bulging out or caving in "here" when you are pressing "there".
Frankly, this kind of thing is tricky to do; you might want to take it to an expert metalworker, perhaps a jewelry smith or experienced metal model builder. Otherwise, take it very slow and easy, and don't force or rush things too much. Think thrice, before acting once.
As for the tonearm not having free horizontal movement, are you sure it isn't supposed to be that way? A few of these fancy arms have servo-control mechanisms that make them feel a bit stiffer than a simple free-bearing tonearm.
The easy solution is to replace the tonearm shaft, but if you do and the characteristics of the replacement are not exactly like those of the original, it may throw the automatic and servo controls all out of whack. Hopefully, this arm is a simpler automatic that won't be so finicky/complicated.
One last thought: is that arm aluminum, or steel? If it is aluminum, DON'T use heat to soften it. Aluminum just gets hotter up to a point, when it suddenly melts. In between, it doesn't get much softer. Steel, however, can be heated a bit to soften it, before bending.
I think we are going with a Manual TT...Arm motor looks blown up! Like Sargent Hulka! Blown up Sir!:D
UPDATE: I found a problem with the dragging motion.
Thanks,
John.:music::D
The arm motor was not working, jammed, not releasing the arm,I am hoping. The tonearm bearings are OK, smooth motion in ALL directions.:yes:
So all it is will be is a new tube!:thmbsp:
Thanks,
John.:music::D
