Thanks, that's very helpful. I'll save them for guitar amp projects or sell them off.Neither approaches a Harman-Kardon transformer of the same size.
ASR -120 output transformers are ultra linear the circuit is a cathode follower. output transformers primary side is 6500 secondary are 4-6 ohm output Ive been using them for yrs pushing 8 ohm speakers 3 way. added a schematic so you can see the power circuit with all voltages plus,Has anyone tested the frequency response or square wave response of these transformers as they're used in the original amplifier? I have a pair that I removed from an ASR-120 (the power transformer was used in another project), and trying to decide if they're worth repurposing for hi-fi. They look a little small, but performance might be OK if materials and winding techniques are good. Anyone have any data?
Jack
I measured it. Part number 161000-184, measured 10K (as would be expected for 6V6) when loaded with 8 Ohms. About 9500 if measured by voltage ratio, unloaded.
I used a Wayne-Kerr impedance analyzer, also at 1 KHz, no longer have access to that or the transformer that I measured.they measure about 11,250 with an 8Ω load. Not sure why we would see such a difference. I did this at 1kHz.
[Note that I revised my earlier post #11]I used a Wayne-Kerr impedance analyzer, also at 1 KHz, no longer have access to that or the transformer that I measured.
In that case, I don't know how to explain this. The 8Ω load should be transformed up in accordance with the turns ratio (plus losses). It's possible the transformers are different, but that seems unlikely.Measurement was was 10030 Ohms, +10 degrees at 1 KHz - phase is insignificant.
I would expect that to be less accurate than simply measuring voltage with the transformer secondary unloaded. I say this because subtracting DCR from the loaded value won't account for all the coupling losses that contribute to the measurement when it's loaded.I estimated an unloaded value by subtracting the primary and reflected secondary DCR.
your wrong sir. the ASR-120 is in fact cathode follower the output transformers are ultra linear. ive had mine worked on by a factory McIntosh 30 yr tech who agreed that it is ultraliner....and cathode follower circuit.Its neither ultralinear nor a cathode follower. This is a standard pentode output stage. 6v6 I'd expect closer to 10k primary impedance.
Sorry, but this is totally nonsensical. It's clearly not what you think, and no McIntosh tech ever told you that. The schematic speaks for itself.your wrong sir. the ASR-120 is in fact cathode follower the output transformers are ultra linear. ive had mine worked on by a factory McIntosh 30 yr tech who agreed that it is ultraliner....and cathode follower circuit.
