I like it! Great picture, too.
Thanks. It still came out grainy....wore out ol' dinosaur camera.....
Those James universal OPT's are hidin' behind those oil caps, BTW.
This circuit sounds like god on my LaScalas, I was really suprised how good it sounds.
Of course all the usual rules for low watt triodes apply....thrash metal and congested sorts of music won't fly....and at 750 millivolts isn't gonna rattle rafters, either.
But in my small place, it gets up to and a bit above moderate listen levels. Plenty loud enough for me.....the tone is what it's all about to me. Buttery smooth midrange and top end. Bass is strong, clean and natural sounding.
I'm using this circuit with a few differences:
http://www2u.biglobe.ne.jp/~tossie/71ASE-E.html#circuit-fig
The 71A's are heated with these little DC supplies my retired EE audio buddy gave me. Xentec inc. Model XE15-3.
The have 120 volts AC in, or 240 @ 60Hz, + or - 10%.
DC output is 2-4 volts @ 3 amps. I use one each for each 71A, and they seem to pull 5 volts running a 71A without breaking a sweat.
I remember bridging two together to try to swing the filaments of two (7.5 volt?) 801A's.....they couldn't do it, and kept tripping the protect mode.
But I got four now....two bridged might swing one 801A...hmmm..
These things eliminate filament growl/line noise with the 71A's. Which is a 5 volt filament.
I'm not used to listening to triodes without a little bit of growl. It's quite interesting and nice.
Some complain of using SS devices to heat with DC on triodes, which is more glare or dullness.
I don't notice this, or don't know really what to listen for, or need to do some comparisions with AC heating.
The 71A's 2K cathodes resistors are bypassed with a 22uF Solen 400 volt metal polys across NOS Sprague 600 volt "Chlorinol" oil caps.
The cathode bypass cap, to the resistor for the first half of 6SL7, is a 470uF 100volt Nichicon Muse.
Instead of 22uF for decoupling for 6SL7, I'm using 100uF 450 volt Nichicons.
I'm using my James universal OPT's. The supposed spec primary load for 71A is 5K. I've been swapping between the 3.5K primary, and 5K primary. I seem to prefer the 3.5K tap, with the B+ at around 150 volts......strange that....
But it seems to sounds less stressed at lower voltage, and more full and open with the lower primary tap.
I may need to tweak with the dropping resistor for the 6SL7 for a lower value, but for a first take this things sounds damn good.
I was visiting some friends last night, (never visit a video junkie who throws in a 6 hour movie, argh...) but I told them I was listening to a amplifier circuit that used 75 year old tubes. That usually raises some eyebrows.
