merlynski
Curmudgeon Electronicist
Did you measure the bias before changing any parts?
At the very least I would power up on DBT, then measure the bias. If it is high on DBT back it down, if it is low on DBT it may be OK. You did post it was working originally upon acquisition.
But, if you did not measure the bias before starting refurbishment, the last guy to set the bias may have been the guy that applied the unsanitary napkin. I would not be very trusting, and I would back it off before powering on again. You have little to lose by backing it off, and may toast some otherwise good parts if you don't . . .
You are probably going to replace the bias pots anyway, right?
