Also, I'd like to get education the VR2 bias. I understand it increases with temperature but does it also increase with volume control? If it does, is it ok to go above 100mV for a few millisecond during audio playback? Or should it be stable below 100mV?
merlynski's explanation is good, and tailored to the sx-1250.
Idle current is a DC measurement - NO audio in the circuit when it is being set.
It is a MINIMUM setting, and as AC is fed into the amp for driving a speaker, more current flows - but it is NOT idle current - the amp is NOT idle!!!
The stv diode is a voltage reference - a rubber reference with the stretching influence being temperature.
The STV diode's voltage is generally specified at 7 milliamps of current on the datasheet. Increasing or decreasing that 7mA WILL increase or decrease the diode's voltage.
Getting the current to run through the diode usually uses one of two methods:
1. Cheaper models use "swamping" by tapping a current from a regulated power rail through a large value resistor, where other effects in the circuit will be swamped by the large resistance.
2. regulated current sources (or current mirrors in differential amp stages) which are active circuits supplying a precise current.
The VR2 resistance added in series with the STV diode is used to gain a certain extra (and temperature constant!!) voltage under the affect of OHM'S LAW.
Voltage expectations:
Output transistors +0.600VDC and -0.600VDC
Driver transistors (Q9 & Q10) +0.600VDC and -0.600VDC
pre-Driver transistors (Q7 & Q8) +0.600VDC and -0.600VDC
So with a direct coupled current amplifier as found in the output section of a Pioneer SX-1250 power amp:
1.8v on base (-0.600v), 1.2v on emitter of pre-driver, then
1.2v on base (-0.600v) 0.6v on emitter of driver, then
0.6v on base (-0.600v) 0v on emitter of output.
thus
1.800v > 1.200v > 0.600v > 0.00v
don't forget, there are the npn and pnp halves of a push pull power amp circuit, so there is another
-1.800v > -1.200v > -0.600v > -0.00v
total voltage needed:
3.6v (+1.8v + -1.8v) into pre-drivers
2.4v (+1.2v + -1.2v) into drivers
1.2v (+0.600v + -0.600v) into outputs
Now, the three above stages get an additional VR2 voltage (say 0.02v)
which the DC offset control through the feedback system splits in half
+1.801v > +1.201v > +0.601v > +0.01v
-1.801v > -1.201v > -0.601v > -0.01v
Notice the final voltages of +0.01v and -0.01v across the power output transistor's emitter resistors? THAT'S your idle current set by VR2.
Hope your eyes aren't glazed - these are the KEYS to the KINGDOM!!!!!
There are 3 parts of a power amp
1. input differential amp (feedback system)
2. voltage amplifier section
3. current driver output section - usually "push - pull" or "class B".
Whenever I am asking for the base to base voltages, I am most likely asking for these numbers to be found in the push pull output amplifier.
