the_burmese
Looks good.
I hope you masked off the heat transfer surfaces for the output transistors, and didn't paint them...
Yeap ..
Looks good.
The 2SA798 is a dual PNP transistor used in a lot of Pioneer power amp designs, and it has a very mixed reputation, but I don't believe there are any in the SX-1250. I did not find any either. It would have been where Q1, Q2 diff amp is on the power amp PCB..I couldn't find 2sa798s in the schematics of AWH-048. Which board should I look for them?
Alright, took it off the DBT. Set the VR2 biases to zero (all the way CCW). Brought it back on house power and waited for about 10mins.
Checked the stabilizer board biases - confirmed +/- 65v
Checked VR1 bias on L and R power amp boards - adjusted to 0v
Adjusted VR2 on L and R power amp boards to around 90mV (for now)
Monitor the VR2 for about 5 mins. It goes up another 2-3mV.
Powered off. Connected the jumpers and speakers.
I realized that the left channel issue may be due to volume knob. The left channel makes a very faint sound even though the knob is turned all the way down. And I could tap a little to make it go away.
I am worried that the pot may be damaged from the impact that had caused twisted knobs on this unit. I will try detoxit tonight and see.
Once the volume is turned up, then both channels are making good sound now.
I am still trying to check again for the faint static heard on the L channel right after the second relay click for a few seconds. It is not clear at this moment.
I also found that the VR2 biases takes a while to get to 90mV from cold start. It seems like 3-5mins. Is this expected?
I don't know about that, he is very resourceful. I have not seen one on AK that was repaired, but there is always a first time.ok i just realized that 1250 used sealed volume pot. Cant clean it. It seems Mark might the right guy to fix the unfixable?![]()
@merlynski
Nope the sound lasted only a second or two. And it doesn't happen if I do a warm start (power on, warm up, off and on again). The relay is quite faster than original - I'd say it is right about 3 seconds now.
And I used to hear two distinct relay clicks. Now it seems like a single click only.
Did you do a complete rebuild of the Protection circuit?
