Here's what
tunerinfo has to say about the SX-3900 tuner:
Pioneer SX-3900. Our contributor Ryan reports, "The SX-3900 has an analog dial and a digital readout. The dial is just like that on a vintage Pioneer, but a few inches longer. It also has a quartz lock, but Pioneer grew a brain since the TX-9800, and you can disable it on the front panel. The tuner has a 4-gang analog cap, and a single gang varactor for the oscillator, so the thing has a 5-gang tuner stuffed inside it. Nice. Stereo sensitivity is great at 36 dBf. The S/N ratio is 78 dB in stereo, which is pretty impressive in any vintage beast from 1980 or so, especially in a receiver. The only pitfall is the single IF bandwidth, which uses 3 GDT filters and two HA1201 IF amps. Even so, distortion is only .2% at 6 kHz and you get 80 dB alternate channel selectivity to go with it. Anyhow, the spurious responce is 100dB, which is pretty decent. The rest of the package is rounded out by a nice toroidal transformer, two 15000 uF caps, and a good 120 WPC output. THD is .005%, but the damping factor is surprisingly only 60 from 20 to 20, which suggests that there might not be all that much negative feedback to pull off the low THD, but good design instead. A 115 dB A-weighted hum and noise suggest pretty good design. Pioneer also developed some updated tuner ICs which are in this thing instead of the old PA1002, etc. which were in their older tuners and receivers. As a transition product (from analog to digital), this thing was probably at the leading edge of analog Pioneer receiver technology."
