Mini Grabbers, no affiliation:
http://www.ebay.com/itm/111533552997?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
I saw something like these when I was looking in Maplins the other day. How do they work? Do they connect to the existing wires on my DMM?
For a silicon junction, usually 0.6-0.7V, so for an npn to turn on, the base must be 0.6-0.7V above emitter
Q9
E - 5.9v (5.4)
C - 21.5v (16.5)
B - 6.2v (6) base is only 0.3V above emitter, this is a problem. Note, should be loaded with at least one lamp beaning turned on, so that some current is passing through Q9 C-E to the load.
Q10
E - 6.3v (5.4)
C - 21.5v (16.5)
B - 5.2v (6.1) the base voltage is below the emitter voltage, this is wrong, the b-e junction is in reverse bias = no conduction from collector to emitter.
Thanks for the information. To be honest, the readings were quite erractic, but the collector was consistently well over 21v.
It turned out all the problems were caused by the power amp board. When I was testing some of the pins, the voltages were as high as 70v (the ones that should have been 51.5v). I had a good look at the board and found that the white wire that connected pin 15 to 30 had broken. But I think it had been intermittently touching the pin. So one side of the board wasn't getting the negative voltage from the filter capacitors. Also when I looked at the heatsink I noticed a pin from one of the output transistors sticking out. It must have bent when I pushed it in. So I guess that didn't help things. After fixing this and another thorough check of everything, it's all good. The voltages are all correct on the power supply and power amp board. And I can set the dc offset and idle bias easily.
I listened to it for a while and it sounds okay. I don't really know what I'm listening for but I'd say the bass is a bit muffled at times, and the treble can be a bit scratchy (can't think of a better way to describe it). So hopefully recapping the tone and flat amp boards will improve it. I also still need to do the equaliser board as Watthour recommended. I've already deoxited all the pots and switches, I might do them again though.
