live 120v, Unit warmed up. All transistors are in. Nothing connected to speaker terminals and speaker select buttons are off. Unit is on AUX with no input signal, balance control is neutral
I went through every transistor and documented the voltages at the pins. The biggest takeaway is voltages are lower in almost every instance 5% - 10%. For example, Q1,Q2, pin 4 s/b -24.5. Mine is measuring -22.4. Pin 5 s/b-23.5, mine is -21.1. Pin 8 s/b +24.7. Mine is +22.9
Q9 B s/b40.3, mine is39.1
The only one running higher is Q35 pin 6 s/b-7v but I measure -12.3v and pin 8 s/b 7.4v but I measure 8.6. This lower voltage is pretty consistent throughout the unit
Looking at B-E difference, I am at 0.6 volts everywhere except the following:
Q7 & Q8 B-E is 0.5 v
Q13 is 0.5v
Q27 is 0.7v
Q10 is 1.3v B=39, C=1.19, E=37.7
Q28 is 0.4v B=14.3, C=40.8, E=13.9
Q36 is 0.15v B=32.65, C=0, E=32.8
Q37 is 0.7v
Q33 and Q34 are both near zero for B and for E, but I believe this is ok
Q1,Q2 are showing -35mvdc to -160mvdc on pins 1,3,6,7 instead of zero. Q3,Q4 pins 2,3,6 likewise are showing some milivolts instead of zero.
in summary, almost all of my reading are different than expected, but at the same time, except for the things mentioned, there isn’t any major smoking gun
