Universities and colleges still teach relevant electronics skills and theory, but interest in vintage gear is primarily driven by nostalgia and fashion so it's inherently self-limiting. As us nostalgists die off, and as fashion changes, there will be -- and already are -- few opportunities even for techs interested in vintage gear to make a living repairing it, and that means limited (and expensive) repair opportunities for the relatively small number of people that will join the vintage audio hobby in the future.Know that it just not what I want to hear. I wanted to hear that the rise in vintage popularity is attracting new techs. But no.
You're never too old to learn as long as you're committed to learning, but as I discovered in my mid-40s, the biggest obstacle to doing the kind of electronics work I did as a teenager was my aging eyesight. I now wear varifocals, which are necessary but annoying. Multiple bench lights and a magnifier are necessary to work on modern gear, and are helpful with vintage solid-state gear. Tube/valve gear I can still see from across the room.So it appears the only units to be properly repaired will be the choice ones worth the big tech fees. Well, I have a Heath oscilloscope. I plan to get a good multimeter, signal generator, power supply, solder station, vari-arc... What else am I going to need just to stand a chance? At 60 am I to old to learn?
Q2 position is a darlington drive element, and thus higher collector current could happen,
Q3 position is a feedback element and gain is better than drive in this location.
Depending on where you are and what you can do, that may represent a problem, or it may represent an opportunity.
You're never too old to learn as long as you're committed to learning, but as I discovered in my mid-40s, the biggest obstacle to doing the kind of electronics work I did as a teenager was my aging eyesight. I now wear varifocals, which are necessary but annoying. Multiple bench lights and a magnifier are necessary to work on modern gear, and are helpful with vintage solid-state gear. Tube/valve gear I can still see from across the room.![]()
I would like for you to retire NOW. This Sansui works needs some love, tiny right channel humDoing vintage audio is a labor of love. There's little money to be made, at least not that I've found, being a bit on the slow and cautious side. You need some years of persistent study to make good choices and repair things without shotgunning it. You need test equipment and a place to work. You need even more test equipment if you want to do alignments. And more study. I know few young people that have an interest, and even fewer (zero?) that want to invest the time. I haven't taken on anything new in quite a while, it taking most of my energy just to do a regular job and keep my head above water. That head above water thing seemed a lot easier a few decades ago. I worked twice the hours and it seemed I had twice the free time to build speakers and play with audio. No matter what nonsense they spout about the economy, it was a heck of a lot better in this area 30 years ago than it's been in the last decade or so. If I can actually retire before I die, and the body still functions, I'd like to service at least a few more Sansui and other nice things, but right now it's tough to fit it in.
It is ok not to be on the same league of the gurus here, go for it.I think I could learn to repair them but I would never have the valuable experience needed to predict the outcome of unobtainable parts substitution
