TECHNICS SL-1200GR2
I thought I would revive this old thread with a quick review of the New GR2 I bought for my B-Day. My first turntable was (still have it) an old CEC made Marantz 6200 mid grade table that is dead reliable but was "meh" in sound, which I fixed with an AT-VM95ML cart and an Oyaide BR-12 mat- its now decent sounding (comparable to a $600 Audio Technica table).
I wanted something better and went with a Project Debut Pro that was quickly sent right back (overpriced POS) in exchange for a Rega P3. The Rega went through all the usual upgrades of sub platter, belt, PSU, better cartridge, and finally a whole new acrylic plinth (SRM Tech "Azure") using just the RB330 tonearm and motor. This one sounds excellent with a AT-VM540 /740ML cartridges. But it is not easily adjustable so I thought I would try a direct drive TT with detachable headshell and adjustable VTF which leads straight to a Technics table.
I looked at ALL the tables Technics makes and decided that the 1200G was too much coin at over $4K, but the new GR2 at half that looked pretty good- except for that ugly industrial/DJ appearance. I found a guy in Spain who makes wood plinths that slip over the top and cover up the ugly black portion of the plinth, turning it into something I (and the wife) could look at in the living room everyday.
The table arrived and I was surprised that it was built like a Tiger tank- the complete opposite of the Rega minimalist vibe. It turned out to be the easiest table to set up I've ever played with, and the speed is near perfect with no detectable fluctuation (my cell phone app shows 33.34 rpm, 0.015 W & F). I put brand new a VM-540ML on it and loved the sound right away, but yesterday I swapped it for the well broken in VM-740ML (100 hours) that was on the Azure TT. The 740ML is just slightly more refined and subtle- it takes off the edge of the brand new 540ML.
The GR2 has deeper bass, the same clear open mids, and airy highs as the Azure. I have the Azure hooked up to a Parasound JC3JR phono amp with built in 150pF capacitive load and the GR2 paired with a Schiit Skoll set at 50pF - the capacitive load is very important with the 540/740ML carts, anything over about 220pF total can cause a noticeable 3db bump in the highs. The GR2 is using Blue jeans LC-1 cables and the Skoll set to 50pF, so there is about 100pF total. The Azure arm was rewired by Brit Audio and has a very low capacitance. keeping it around 200pF total with the JC3 Jr.
The Rega P3 based SRM-Tech Azure "space ship" is a nice to look at table that sounds much better than the stock P3, nearly exactly like the 1200GR2, and in the end they both cost about the same, so I'm kind of wishing that I had forgone the Rega experiment and went with Technics first. The Rega RB330 is a better arm but the rest is inferior- the Rega light weight construction and puny motor compares like a plain Chevy to the Cadillac quality of the GR2.
The GR2 has deeper bass, the same clear open mids, and airy highs. I have the Azure hooked up to a Parasound JC3JR phono amp with built in 150pF capacitive load and the GR2 paired with a Schiit Skoll set at 50pF - the capacitive load is very important with the 540/740ML carts, anything over about 220pF total can cause a noticeable 3db bump in the highs. The GR2 is using Blue jeans LC-1 cables and the Skoll set to 50pF, so there is about 100pF total. The Azure arm was rewired by Brit Audio and has a very low capacitance. keeping it around 200pF total with the JC3 Jr.
View attachment 3205977View attachment 3205980View attachment 3205981View attachment 3205982
Thanks, for the review!
Just oil the shaft when appropriate, and that table will last forever. :thumbsup:
That's interesting, @krautmaster !
I have now a Technics SL-1200G turntable on which I installed an Audio-Technica AT-VM540ML :
I measured the capacity of the cables, and found 85-87pF :
I estimated that the capacity in the arm would be circa 25pF, and the input capacitance of the preamp at circa 100pF, so it gives 25+85+100=210pF estimated... I tend to find that the tone is bright (no matter the preamp used, tube or SS), while AT recommends 100 to 200pf for the VM-540ML.
Then I am at best in the high range of total capacitance (maybe over), so reading you, it may be an explanation of this brightness...
Is there a very simple mean to correct tentatively this capacitance, at least for a comparative listening test ?
T
T
Try a set of Blue Jeans LC-1 cable, they say they have 11pF per foot (I have 39" ones so about 42pf total). Does your phono preamp have adjustable capacitive load? If so set it at the lowest one available (my Schiit Skoll has 50pF, 100,150, and 200 settings to choose from, I use 50pF).
I use the zero pico-farad setting for MC cartridges. --- using old-school Aquioquest cables.
For my Accuphase AD-50 phono card = 47K + not specified
For my McIntosh C712 = 47K + 65pF
For my NAD 114 = 47K + 200pF
For my SRPP Anzai (tubes) = to be measured
For my Micro-Amp = to be measured
None of them have adjustments...
Update :
I tried to measure the characteristics of my preamps, but unsuccessfully (or rather inconsistently), thanks to the // association of the input R and C, plus the tube or transistor residual input capacitance...
On my SRPP Anzaï preamp, I estimate it at 50pF maximum, including the small length of shielded cable from the Phono plug to the ECC83 input grid, plus the input Cgk+Cgp of the tube, minus the capacitance of the measuring cable (110pF).
For my Micro-Preamp, which has a 100pF between base and GND on the input transistor, plus a few cms of shielded cable, I think the total is possibly about 150pF...
On my Audio-Research SP3A1, the ARC spec indicates "47K + 150pF Typical", but there's 2x39pF Miller / RF compensation at the input, plus a more important shielded cable length, via a frontface MAG1 MAG2 phono switch, so this explains why the 150pF value is reached, I think.
For the others - for which I have no specs - This still remains a guessing, riddle estimate...
T
A phono preamp with 150pF all by itself is just a bit too much capacitance... my Parasound P6, JC3Jr, and Z phono all have 150pF and they make the 540/740 sound too bright (when you add in the capacitance of the cables from the tonearm to the preamp). You can get some low capacitance cables and/or try setting the cartridge tail down by turning VTF wheel down as low as it will go.
It's one way to do it, but as time goes on, I have less and less patience with the concept. The motor on my P3 is indeed puny. It's also very cheap looking, like everything else on the turntable bar the arm and - perhaps - the platter. The decision to go with three feet, presumably intended to give audiophile vibes, means that the whole turntable tips easily if you place your hand on the top towards one of the corners not supported by a foot. While it could be argued that there's no need to put your hand there at all, it's easily done unintentionally. And it's a reminder of why other turntables have four feet in the first place.
I don't exactly see why this setting would reduce capacitance, @krautmaster : would you light me ? :confused:
T
It won't decrease the capacitance at all, but it changes the angle that the diamond contacts the groove... with the nose down the stylus contacts the groove like this \ ... and with the tail down it contacts this way /... which changes the sound produced.
Ah OK - I see - Thanks !
T
T
Total C and cartridge L create a resonant circuit with an MM this is usually in the region of 14-18kHz. As C increases Fo decreases which can manifest as bright sound. Try lowering the 47kR load resistor with another resistor in parallel. This will not alter Fo but will lower the Q of the circuit smoothing the resonant peak. Ideally you would increase the Q so the peak was narrow but this requires replacing the 47kR resistor with a larger one and if you go too far it could cause ringing.
When I set my Grado up I used a couple of trim pots in parallel on the input to tune this then replaced them with fixed resistors once I knew the value.
Not sure what you mean with "C" and "L" and "Fo" and "Q" (maybe spell them out once?) ... My test records shows a resonant frequency of 8hz with the 740ML on the GR2
Sorry
C = capacitance
L = cartridge inductance
Fo = electrical resonant frequency
Q = simply put is the width of the resonant peak low Q is a wide peak.
8Hz is the arm cartridge resonance which is NOT what I'm talking about. This is a mechanical resonance formed by the spring mass damper arm and cartridge compliance (spring)
The C and L form an electrical circuit that resonates at a particular frequency. Most MM cartridges this resonance is around the 14-18kHz region. You mentioned your system sounded bright this is most likely caused by this electrical resonance boosting frequencies in the 14-18kHz range. Changing the load resistor can improve this brightness. It will not alter Fo but will alter the width of the resonant peak (Q) making it less annoying.
I thought I'd add a little more info for you.
If you decrease C or L Fo will increase, this is why some like MC cartridges their very low L moves Fo out of the audio band. Some of the top tier MM's from 40-50 years ago like Technics EPC 100 and 205 lowered coil inductance at the cost of lower output MM's 1-2.5mV
