TECHNICS SL-1200GR2
The headshell that came with the GR2 has a very tiny common slotted screw in the bottom to adjust the azimuth if needed. You'd need a jewelers screwdriver to fit it, it is very small. (sorry for the crappy pic, it's the best my ancient camera can do)
Thanks. I don't want to take this thread off its purpose. I'll just mention my experience.
I've tried that on one of my tables. The set screws seemed too tight to risk rounding the hex or damaging bearing with too much torque. I just found it less risk and trouble to have Azimuth adjustable headshells.
And I've found that headshells themselves can have a lot of Azimith variation. It can be a mix and match of TTs and headshells. Change headshells and get different Azimuth results. I worked in manufacturing. And I know aligned headshells can be made. But I've found few makers do.
I also use button size bubble levels.
Those screws are held in by what seems like Loctite. Another problem is there is not enough room to use a conventional screwdriver. The arm won't swing out over the turntable's chassis enough (hits the armrest).
You need the correct Philips head screwdriver to avoid rounding the slots. I used a computer's PH0 bit from a game console tool kit and needle-nose pliers to loosen them.
The SME 3009 arm swings out & up far enough to use a conventional screwdriver (also a PH0 tip).
KABUSA sells the headshells with Azimuth adjustment, that Krautmaster mentions are standard on his new 1200. I haven't yet tried one. But they look like a good design. I have no connection to KABUSA.
Once aligned, it should be good to go forever --- unless you buy a tilted cartridge. :(
And I've found that headshells themselves can have a lot of Azimith variation. It can be a mix and match of TTs and headshells. Change headshells and get different Azimuth results. I worked in manufacturing. And I know aligned headshells can be made. But I've found few makers do. It's more expensive to make higher quality products.
Button-size bubbles are nice! I bought one from a Japanese seller on eBay. It's an Audio-Technica product that seems to be not sold in the US.
Here's a generic one on eBay. I'm sure that it will work, too.
Headshell Bubble Level for Tonearm Azimuth.
I played the new Concorde for about 4 hours this afternoon...it is marvelous on this tonearm ! There is some great synergy going on since it was designed to work on Technics tables. I had some Santana going for awhile, man did his guitar it sound good, much better sustain on the notes and the humbucker pickups had nice growl. My MoFi 45 RPM "Brothers In Arms" likewise was burning ! (had a new quad of date matching mid 1950's Sylvania Chrome top 6SN7GTB tubes in the Freya+ which make the Concord sing).
I'll not be putting the VM740ML back on the GR2, it works much better on my Rega/SRM Tech Azure table in the office. The Concorde has much better mid range and a top that is not as bright on the GR2 arm. The 540ML/740ML work really well on the RB330 arm, so I'll use it as a spare for the office table which currently has a 540ML on it.
I'm not sure I'd be putting any bubble level on the headshell without first reducing the tracking force to compensate for its weight ...
IMHO, @Mr Boochie possibly spoke about a left-right Azimuth level static control, I mean : the tonearm being released... Or I missed something in the process ? :idea:
T
Yes, you need to readjust the tracking force to compensate for the weight of the bubble level.
Use one of these.
Be sure to set the force back after you are finished with the bubble level.
Ah, OK : so it's me... :rolleyes:
I would have thought that the test would have been done the tonearm set horizontally first in longitudinal position, with an appropriate shim under the arm itself, out of the cartridge and stylus zone, an then you would correct the azimuth by rotating the headshell accordingly to make it horizontal too.
Doing this, you don't need to change any antiskating or tracking force setup on your arm, nor use any compensation mass, since the cartridge is not involved in the process, but only the horizontality of the headshell.
I hope I'm clear in my description... Or I am still missing a point again ? :idea::idea::idea:;)
T
I rest the tonearm on an average weight LP. I don't play many 180 grams or more records.
Now that I have an Ortofon Concorde Music Bronze cartridge that takes a capacitive load of 150pF to 300pF on the 1200GR2, I have put my Parasound JC3 Jr phono amp back in the main stereo with it as it has a fixed 150pF capacitive load that pairs better with the Ortofon than the AT cart on my Azure table. I placed my Schiit Skoll in the office to run the Azure with an AT-VM540ML cart that needs considerably less loading (100-200pF max), the Skoll is adjustable(50-100-150-200pF) and pairs better with the AT-VM540/740 cartridges than the JC3 Jr.
Both tables are sounding wonderful now. I may (?) buy another Skoll when they are available in silver and sell the JC3 Jr, but it is working very well with the Sl-1200GR2/ Concorde cartridge.
