TECHNICS SL-1200GR2
That is well beyond my hearing range, which pretty much drops off a cliff above 12 Khz (old age related)
540/740 Fr is at around 12kHz, and as there's a "width" (Q), the deviation starts around 6kHz. You can lookup some measurements here for a visual.
For clarity, I use Fr to denote resonant frequency as the more common notation - F0 is typically used for mechanical systems for natural frequency or fundamental frequency.
I pretty much ignore most things that hack Amir says... testing is one thing, but listening is far more important and that is exactly what he doesn't do.
Total C and cartridge L create a resonant circuit with an MM this is usually in the region of 14-18kHz. As C increases Fo decreases which can manifest as bright sound. Try lowering the 47kR load resistor with another resistor in parallel. This will not alter Fo but will lower the Q of the circuit smoothing the resonant peak. Ideally you would increase the Q so the peak was narrow but this requires replacing the 47kR resistor with a larger one and if you go too far it could cause ringing.
When I set my Grado up I used a couple of trim pots in parallel on the input to tune this then replaced them with fixed resistors once I knew the value.
Yes @warrjon - thanks !
That's what I was inclined to test : a // resistor to lower the resonant peak by damping, in order to hear if there's an interesting change in tone.
T
He does listen, but regardless he has nothing to do with what I linked you to. Understanding how to correlate what one hears to data isn't a bad thing.
Yes, but you have gone way too far down the rabbit hole for me. I match the compliance of the cart to the tonearm, align it as near perfect as I can get it, and then enjoy it.
If I had a dedicated listening room all set up for perfect acoustics and a $10K table, then I would go down the rabbit hole with you, but since I have a $2K turntable in my big open living room (18'X25') that has to comply with the wife's idea of what is acceptable, well then, I just do what I can to make it as enjoyable as possible. :)
Yes, but you have gone way too far down the rabbit hole for me. I match the compliance of the cart to the tonearm, align it as near perfect as I can get it, and then enjoy it :)
That's fine. I'd rather know if what I'm getting suits what I like before spending money or time.
My wife did not care for the orange color of the wood plinth, she wanted it to go better with the "Rosewood" color of my speakers, so I sanded it down to remove the wax & oil finish then gave it a base coat of Barn Red followed by a top coat of Red Mahogany... I could not match the color to the speakers, but it is close enough that she is happy with it, and I think it looks a whole lot better:
So I have been playing the $$it out of the GR2 with lots of different sets of tubes in the Freya+. Table sounds good with most, but right now I'm getting the best vibes from a set of mid 60's Sylvania 6SN7GTB in the gain stage and a very similar pair of RCA's in the buffer stage (both have black bases with red script), very smooth and sweet and I can understand a lot more of the lower volume lyrics that before were kind of mumbled... This turntable is fantastic !
I ordered one of those new Ortofon Concorde Music Bronze cartridges to try out on my 1200GR2... these are not DJ carts with a round stylus and 5 gram VTF, it uses a Nude Fine Line stylus with 1.8 gram VTF and no struggles trying to align the thing perfectly.
Give us a review once it's up and running! :thumbsup:
The Concorde is installed (soooo easy to set up) and playing nicely. It opened up on the 5th album side (2.5 hours, not 20 or 30 hours). Easily sounds as good as my well broken in VM740ML and not quite as bright on the top end while the mids are a bit better (voices just a tad clearer).
Installed the cart, balanced the arm (plenty of adjustment left without using the extra counterweight) added in 1.78 grams of VTF and 1.5 anti skate, set height to +3 mm to make up for the taller cart and thicker mat. I added in 200pF capacitive load on the Skoll preamp (specs call for 150-300pF) then played music--no fiddling around for an hour or more aligning the damn thing. I love it!
The package contains a .5mm thick rubber gasket to use with tables that require a 52.5mm overhang (some older Pioneer models and a few others) The Technics uses a 52mm overhang so the extra gasket is not needed (I had to look this up, as there are no instructions with the cart).
Only one small negative: the output is much higher than the 740ML (6 mV vs. 4 mV) so it does pick up a tiny bit of background noise / pops/ clicks if the records are not super clean (I had to pull DSOTM off and run it through the record vacuum, it was noisy as hell).
Very cool. Ortofon is kind of my go to for years now. Not only do they make excellent cartridges but their support (both on the website and via email) is top notch. They have so many great tools available.
I have an SL1300 Mk2 that I used an OM-20 on forever. For the last few years, I've been running a DV10x5. Maybe one of these new Concordes finds its way on that table . . . who knows . . .
I would not bother with either the Red (elliptical stylus) or Blue (nude elliptical stylus), you get the good stuff with the Bronze (nude fine line stylus) or Black (nude Shibata stylus)
View attachment 3253917View attachment 3253918View attachment 3253919
Is there any Azimuth adjustment? I don't see any mention on Ortofon site. My Sl1200 mk2 and other S arm's have a little off Azimuths.
Yes, I see : there's also those screws on my SL-1200G (extreme right on the pic below)... Thanks for the tip @Mr Boochie, just in case ! :cool: ;)
T
You must also loosen the knurled collar holding the headshell onto the tonearm to rotate the headshell.
The small screws on the bottom are very short. So be careful loosening them, or they may fall off and go to God only knows where. ;)
There are two set screws on the bottom of the tonearm by the headshell attachment. Loosen them slightly, and you can rotate the headshell. I use a bubble level to set the adjustment.
Thanks. I don't want to take this thread off its purpose. I'll just mention my experience.
I've tried that on one of my tables. The set screws seemed too tight to risk rounding the hex or damaging bearing with too much torque. I just found it less risk and trouble to have Azimuth adjustable headshells.
And I've found that headshells themselves can have a lot of Azimith variation. It can be a mix and match of TTs and headshells. Change headshells and get different Azimuth results. I worked in manufacturing. And I know aligned headshells can be made. But I've found few makers do. It's more expensive to make higher quality products.
I also use button size bubble levels.
