Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
I just bought an SL 23 for $15 at a bid to buy store. The platter doesn't spin but it does power on. Replacing the belt seems like a cheap enough fix... is this a decent Technics turntable?
I had a similar problem with my SL-23, I put a little light machine oil on the motor and then turned the motor by hand with the power applied, and that did the trick.
By the way I let run that way for about hour without the belt, applying a drop or two along the way.
goodluck
Edit...After rereading your initial post, if a new belt doesn't fix your problem, the above may apply.
I bought an SL-23 new in 1976. Put a new belt on it, cleaned the speed adjustment pots with Deoxit and installed a new cartridge. She still plays like a charm. You did well on your purchase.
I think that I've heard them called 'Techniques' more often around these parts...East Coast U.S...
Saying that you've just bought a Tech Nic has always sounded a bit White Van...
It looks to be an (1) year Earlier version of the SL-220, which I have...They are in fact Great Tables for the Price...I use the SL-220 for Back-Up, and Pool Parties...
