mzeitlin3348
See it and Believe
Will the SL-D3 motor control board replace a SL-D2 control board? They look identical.
Post a photo of what you need. Someone here might have a donor available. Hint, hint
check vinylengine for the service manuals. create a login there and check part numbers. I love my SL-D2 I bought in H.S. which is still playing after all these years.
If you're not in a rush, I'll try to disassemble the table this weekend. Let me know if you're interested.
Keep us posted
Hi..this is Gazza from Perth/Australia. I have a SL1700 with exactly the same issue and suspecting the IC AN630U after cleaning pots, replacing 6 caps and 2 transistors. My motor speeds up after unit warms up after playing 2 record...generally happens on the 3rd record played in succession. I've also put this motor in my SL1600 as I have 2 TT's..motor works fine ...no speed issues.
I'm interested to know what your outcome was after replacing boards. I'm contemplating buying this IC from AliBaba as it is only a few bucks. On the SL1700 it is not possible to take the bottom off and trouble shoot so I have to go by trial and error .
Look forward to hearing from you
