Technics SL-DL1
The AT92E is a good cartridge, and a solid recommendation for someone looking for a p-mount cartridge. They are readily available at a good discount from their list price, particularly when packaged in a plastic blister on a card (the CD suffix on the model number).
If you are interested in spending all of your budget, I'd recommend a new-old-stock ADC PSX-30 from LPGear. A search should find you several threads about this cartridge.
[edit]
http://www.audiokarma.org/forums/showthread.php?t=370762
The AT92E with the elliptical would certainly 'fit the bill' and get you started. However, the AT92E shown lower on the same page with the Shibata stylus will be a BIG step up (as it should be for $120 more). Get the cheap one and see how you like the SL-DL1. If you like it, spring for the Shibata cartridge. It is never bad to have a back-up cartridge.
There is also this one:
http://www.turntableneedles.com/AT92E-Cartridge-wHyperElliptical-JICO-Brand-Needle_p_4081.html
Which is sort of halfway in between the two.
I ended up buying this table yesterday and everything works perfectly on it and some one replaced the cartridge on with a newer technics P510s with minimal wear on the needle.
I going to buy a new tonearm belt and the cheap cartridge from turntableneedles.com just to try it out and see if it sounds any better.
