Schematic's not going to help you. The whole amplifier consists of the SVI2105 module. If one channel in it is borked you have to replace the whole chip. You could try to swap the inputs on it to see if the fault stays at the same channel. Having said that, I've had cases of bad output relays that would create audible distortion. However, that usually went away when only using headphones. Also, replacement modules aren't
that expensive:
Tjerk, 9ZZ
