Yes, there can be. You just need to read the datasheets to find out.Quick question: are there differences between the various versions of a given chip besides SOIC and DIP? The retailers usually have several product numbers for the same numbered chip that appear identical. Some versions are a few pennies more than others.
Depends on what you’re looking at. Oranda has been testing out more models for the bugle and can tell you what works best.Quick question: are there differences between the various versions of a given chip besides SOIC and DIP? The retailers usually have several product numbers for the same numbered chip that appear identical. Some versions are a few pennies more than others.
I'm following his most recent suggestions. I was referring to chips with the same basic number, like 1358, that also have a few varieties of the same chip with different suffixes after the numerical designation.
Good tip, thanks.Those suffixes are usually documented in the documentation for the chips themselves. They often have to do with pretty mundane things like the sort of plating on the leads.
When ordering I typically look at the stock levels of the various varieties and buy whatever everyone else seems to be buying.
It can be pretty easy to tell based on inventory levels at places like DigiKey and Mouser.
Was it a new 1358? Glad you got it going! Hope you get the U3 upgrade sometime and let us all know what you find.Wee update: I managed to get a 1358 installed without frying it by wearing a little wrist strip attached to ground at an outlet. All I can say is Oranda nailed it. The sound is way less compressed and more 3D. Next up is the middle position opamp. This can wait. I'm digging the sound of the MC with the upgraded power supply and the 1358.
If you can take a pic of your MC we should be able to help you. It should be the middle cap of the 3 caps on right and left of the middle opamp in the u3 position. They are the blue caps on the right and left on the board in my pic. In front of the biggest cylinder ZN caps I installed. I hope this helps.Yes, I started over with a new 1358. At some point I'd like to drop in a silver mica cap. However, I'm schematic challenged and can't decipher which caps on the board correspond with those in the schematic. The MC is subtly different from the 3.
I have had the same experience with my recent build and it turns out that one power supply is a little loose. The other is fine. I wouldn’t worry about it if it is working okay. It’s not like you need to unplug it every day or anything like that?One note: the plug the Jameco power supply is loose in the socket of the MC.
