Updates... I know it's been a while, but I have been busy!
The other cabinet:
I began working on the other cabinet. At first (and second, and third, to be honest) inspection it would have appeared to have been spared the water damage that the first cabinet suffered, but oh boy was I wrong. I had it roughly 2/3 of the way complete when I started using both cabinets lined up together for sanding reference and made a startling discovery, the other cabinet was roughly 3mm taller than the first. My initial thought was, and I had thought this originally when I started working on the bottom of the second cabinet, that it looked like whoever assembled it was a little sloppy in lining things up, and the bottom panel protruded out a bit as a result. While I still could make the argument that the builder wasn't at their best when putting either cabinet together (IMHO it seems to speak to the design of the speaker itself, I would speculate than Dahlquist himself would have nixed the woofer if he could have gotten away with it... the cabinets are under-designed IMO, and almost seem like they were more of an after thought, but anyways enough of my opinions, I wasn't there, I'll never know for sure) what I discovered is that the second cabinet had received just as much, if not more, water damage than the first, however it was less apparent. Being a perfectionist, I just couldn't stand for the height difference being so great, so I gathered my tools and went to see what I could do about it. I started by playing with some coarse sanding, knowing that if that was the solution it would be a lot of work to level it down, but as I started digging into some spots it became apparent that the bottom wasn't protruding just because of how it was assembled, it was protruding also because the entirety of it had been water damaged and had swollen. At this point, I made the quick decision to remove that bottom, grabbed some chisels, and committed to that decision. The surface of the bottom was stable due to having used wood hardener over it, but using the first cabinet as a guide and digging in, with little force of the chisel the entire bottom layer began to come off quite easily, underneath it was a layer quite reminiscent of the damaged edge of the first cabinet. After several hours I had removed quite a bit off particle board, but had gotten it down to an acceptable level. Next, I mixed up another batch of Liquid Wood (I really do love those Abatron products) and had it soaked. After curing it all with heat I was left with a stable, however quite rough, base from which to rebuild. It took several applications of the companion product, WoodEpox, to lay down enough filler to where it could be sanded level, but I think I got it close enough to work. Right now I still have some serious sanding left to do on cabinet number two, but have been distracted by learning how to veneer while veneering the first cabinet.
The first cabinet:
I don't want to get too excited yet, especially considering I just had my first major veneering issue (let's just say that applying the veneer is easy, trimming it is where the real danger comes in) that required me to replace a panel, but otherwise it looks, well, it looks pretty awesome. I will definitely write up a much longer post on this when I am feeling better (I got to spend the day in the ER earlier this week, don't worry, no covid, but it's had its effect nonetheless), and once I have completed the... okay, let me start over, veneering, as many of you have probably seen claimed, is easy. Choosing to veneer 40 year old, repaired-from-water-damage, no 90 degree angled, Dahlquists is... an absolutely questionable first-time decision, however I am already quite satisfied with how the first cabinet is turning out, even knowing there are imperfections (most of which I will be able to hide when finishing).
Wait, what? No pics..? Sorry folks, I haven't had the time to go through the laborious process of uploading them all from my phone, neatly cataloging each in the correct folder, labeling each by what it is, what's been done, etc that comes before me posting a fraction of them on here. Besides, I want to at least make sure that I can get the first box veneered in a presentable way before posting! Pics coming soon!
