Sonic Comparison
Christmas Eve means lots of great music -- which gave me a chance to finally listen to the Bogen for the first time, and now, operating in stereo mode for the first time as well. For the test, the one modified amplifier of the MO-200 was designated as the Left Channel, while the other original amplifier was designated as the Right. The stock (Right) channel was converted to exactly follow the schematic of the MO-100 (requiring only a change to the NFB loop and cathode resistor of the AF Amplifier stage), complete with it's four output tube operation and bias supply (the latter being identical to that of the original MO-200). The modified (Left) channel represented the schematic I've previously presented, and operated from the new bias supply, but without the benefit of EFB just yet. Both channels had their available controls adjusted for optimum operation.
The now stereo MO-200 was driven by a Scott LC-21 preamp, with my trusty Denon DCD-1520 providing the source signal. Much of the material played was Mannheim, but there was also a healthy dose of vocal material as well. The Bogen was driving my 8 Ohm Cornwalls, with the speakers attached to the OPT taps in each channel as designated on the modified schematic for 7.6 Ohm operation. An available 200 watts RMS and a pair of Klipsch Cornwalls places this getup in earth mover territory!
Because the modified channel has the same input impedance and sensitivity characteristics as the original channel, no padding was necessary for either channel to match their output levels for a well balanced and focused sound stage. The Scott allowed for listening (in part) in Stereo, Mono, Left Only, and Right Only modes to really listen for differences in presentation between the two channels.
From a sonic assessment standpoint, Double Blind A/B testing is the only way to determine if progress is really being made with a design, as emotions and psychological factors can so very easily cloud honest assessments if any significant amount of time elapses between one test to the next. But since it takes at least two people to conduct double blind testing (one to control the test, and one to assess), the approach I've used here is about the next best thing you can do: Modify only one channel at a time, and regularly compare the results to the other unmodified channel as the modification effort progresses. I used that approach with the recent re-engineering of a Fisher X-1000 project as well, and the results it produces can be brutally honest: Many times, your improvements are not all that you thought they were going to be -- or, the original design just wasn't as bad sonically as you thought it was. It truly allows you to showcase the difference any modification makes by allowing for instantaneous comparisons, which then allows you to judge for yourself the worthiness of any proposed hotshot modification -- be it mine, or anybody else's!
In this case however, the differences were pretty easy to spot. While the original (MO-100) channel sounded "good" when playing for long periods by itself, instant comparisons to the modified channel showed rather immediate differences: Compared to the modified channel, the original channel had a forward midrange, and reduced (thinner) bass response. It also lacked a level of HF detail, that by comparison came off as present, but dull. And there was one other element as well. The original channel produced a comparatively lifeless sound to that of the modified channel.
Against all of this, the modified channel had very solid, extended bass, balanced midrange (no longer forward), and more detail in HF production. It also had a live, dynamic sound that the original channel was missing.
None of this was a big surprise, really. The lifeless sound is a direct result of the original channel operating the output tubes at such low quiescent current levels, the thin bass response due to very short time constants in the coupling circuits between the phase inverter and output stages in the original design, while the original NFB network produced a notably rolled off HF response. The results clearly indicated that moving forward with the modifications were worthwhile, beyond that of simply splitting the individual amplifiers apart to effect stereo operation.
Since all of these listening tests were done at relatively low power levels (let's face it, Cornwalls don't need much power to get loud), I augmented the listening tests with high power tests as well. I mean really, who in their right mind would connect 100 watts RMS per channel up to Cornwalls? As it was, I used duplicate ground connections between the preamp and Bogen as a safeguard to make sure no 100 watt loss of ground bursts hit the speakers -- or my ears!
For this test, the best I could do was to use my load array set up for stereo 100 watt 16 Ohm loads connected to each amplifier appropriately, and then power the Cornwalls through an appropriate series resistor to maintain a normal sound level. My average and peak indicating stereo power output indicator was then connected across the output of each channel as well.
This type of operation is not exactly the same for the amplifier as a loudspeaker connected and producing 100 watts of power, nor to the speaker either with a now very reduced damping factor. But it is close enough to get an idea of high power performance characteristics at elevated power levels.
At 50 watts of average power output (APO) per channel, both channels treated this power level as a walk in the park. By 75 watts APO, the modified channel was still very clear, while the original channel was starting to take on a somewhat strained element to its sound. At about 80 watts APO, the modified channel was still quite clear, while the original channel was starting to produce that pumping, pulsating effect, that I described two posts earlier. At about 85 watts APO, things were still very good in the modified channel, but the original (MO-100) channel had completely broken down to a wild pulsating/pumping effect, exactly as I had heard in all those MX-60 amplifiers, so long ago. At 100 watts APO, the modified channel completely retained its composure, but of course clipping could now be heard on peaks, as peak power was now indicating over 215 watts in the modified channel! At this point however, the original Bogen channel had completely lost its composure, producing about 165 watts peak power output (best guess with all the pulsating going on).
So, it was an interesting test. I just thought I'd pass all the results along while they were still fresh in my mind. Pics include:
1. The new bias supply is completely installed now, providing bias for the modified channel. The whole power supply area almost looks vacant now compared to that when received (post #1)
2. But to have the original channel operate at its intended bias level, the original bias supply was carefully reconstructed using my best air connection techniques, and connected umbilical style through some cooling holes to provide bias for the channel now configured as an MO-100.
3. All connected up in the listening room, ready for a day's worth of listening in stereo.
4. Here, the bias umbilical can clearly be seen. The front driver tube and four front output tubes represent the MO-100 channel, while the rear driver tube and two output tubes represent the modified channel.
5. Don't be fooled. Those two rear output tubes blew right past the four in front of them. Here, the rear two tubes are producing a surprisingly clear APO of 100 watts RMS, while the front four tubes are pulsing the sound in and out at about a very distorted 85 watts RMS.
On a side note, the power transformer in this puppy handled all of this day's activities in stride as one cool customer: It only became moderately warm to the touch!
Some time off for now.
Merry Christmas everyone!
Dave
