Not sure what tweeters you're using right now, so I worked with the stock ones. I left the woofers connected to the spring terminals, ran leads from the tweeter out the port, and plugged the port with the wires there.
Green and green/black are the woofer leads, and yellow, yellow/black the tweeter. Results are not very good just using the N19 stock and crossing at 2.6 kHz:
The Zobel is wrong for the Presidian woofer. Remove the 18 uF non-polar electrolytic on the terminal strip and replace it with a 6.8 uF metallized polypropylene Dayton. Short out the 5-Ohm resistor, also on the terminal strip, by bridging across it with wire.
Better?
Attenuation control set to "5", we're crossed at 3.1 kHz, and the woofer hash is well buried:
