I assure you the lead wires in Rega are secured into place. The glue, grease if you want, is s semi setting compound and very sticky that if just pulled on will snap the lead wires. There is a way to do it and coils are always realigned regardless of the hurdles by anyone retipping worth his or her salt. My point is it is impossible for the coils to be in the position they are and have moved there in the accident especially when the cantilever is just bent with a kink and to correct the coils the diamond would no longer point down, I have seen this which indicates that the coils were not correct from the factory. I am sure this is not every case but I assure you I have seen it. Further unlike on thr Rega MM it is quite difficult to rotate the cantilever in the suspension indicating in the case of MC at least they are glued to the cantilever further making rotation difficult in an accident.
I like in some ways the design, but I do feel thr lack of a tie wire is allowing too much stylus movement both back and forth and rotationally. I feel this is why thr separation is not so great, I can't think of any other reason.
I feel you are a bit sore about thr MM discussion. The frequency plot is one reason i dont like them, the other is i have seen inside as shiwn and it is not good.
Re Grado tell me what mistake I have made re the grado stylus? I don't know everything, I lean more about our hobby every day, but I have only found 3 pieces on a Grado cantilever when dismantling it not the advertised 4. I would be very interested to know what the 4th piece is. Tell me please what else I have misunderstood?
I have no battle with you or anyone else this is just hifi and it is supposed to be fun.
Chris
