Tips on using dinosaurs receivers?
Now the subwoofer outputs working , perhaps my klh was defective with this particular model or powered itself off .
Now I’m getting this again , I need special clips for vintage screw speakers ?
Maybe I exceeded ohms ?
Can you split the sub signal to hook two subs ?
Any help why do Sony say push power protect??
Do I need a better surge protector?
Let's try this again.
I thought your receiver was an Onkyo, and the sub is an Optimus. How did KLH get into it?
[Edit: I searched this thread for 'klh' and found only two occurrences, yours and mine. So I'm not crazy! It has not been mentioned at all in this thread.]
Getting what?
No, you don't need special clips for vintage speakers with screw type inputs, as long as you securely fasten the wire under the screw and don't leave any strands flying about.
You can't 'exceed ohms.' If the impedance of the speakers is too LOW, that can stress the amp, by exceeding its output limits.
Without knowing what is hooked up to what, it's hard to say.
If they are both powered subs, it should not stress the amp to do that, using either low (line) level or high (speaker) level outputs.
If you are using a sub power amp section on the receiver to power passive subs, putting two subs on one amp channel would probably overload the amp.
Hard to decipher this one but it sounds like an overload breaker has tripped and needs to be reset. You should find out why this happened so it doesn't happen again.
That protects equipment from voltage surges from the power company. It will not protect your equipment from itself, or from the way you hooked it up. So no, it has nothing to do with your current problems.
All due respect, whoever said you need to tighten up your string was right. Try to focus on describing precisely what the symptom is and how the gear is hooked up, so we can follow you. When you're asking all kinds of hookup questions, it's likely we have no idea how things are actually hooked up with the magic smoke is let out.
Thanks hope it is resolved.!!
I unplugged the Optimus it was too low a ohm load for the receiver . I’m using an active sub, maybe I need to check my connections the spring loaded cable things suggested I only have 8 of .
I'd be more concerned with any one of those pin connectors touching another at any second now!
Someone in this thread told me to use them are the causing the receiver to shut off ??
There not side shielded like banana plugs ?
I can use thinner wire
Explains the problem... do you need to wrap em in electronically tape ?
Use thinner wire for that Sony device. 18 awg should suffice. Twist the strands together really well before inserting into the clips.
The watts pillow the load everything strawberry.
Tuberculosis!
What’ a old amplifier, I mean why would they need a 5.1 check output to run Dolby digital is thee anyway to trick the system ?
Nothing has this output ....
That's the way things were made back then - 5.1 direct input. Times have now changed. Technology tends to do that.
Ahh so it’s either pro logic or nothing ? I’ll never find a DVD player with this input or the cables .
It’s probably the dumbest thing I ever saw on the back of a receiver .
Guess I’ll be using everything else then what a worthless input 5.1 ch dumbest invention since hd dvd .
O well it’s other modes are sufficient just lacking on the surround channels .
It may have some bad capacitors too I heard static when nothing was playing .
HD DVD was quite good, Toshiba left the scene because they saw the writing on the wall for physical media. Why battle Blu Ray for a shrinking market? DVD A was also quite good.
