Hey Rob I have the 2nd one (the eBay link) on order, it should be here in a few days, will post my findings.I dont have the confidence to put together a kit
Which one of these will sound better?
http://www.yuan-jing.com/tpa3116-class-d-2-0-stereo-power-amplifier-50w-50w
http://www.ebay.co.uk/itm/Latest-HI..._HomeAudioHiFi_Amplifiers&hash=item4183726afb
or an used FleaWatt
Thanks
Robert
Most times Sure has SD contact, a simple switch to gnd will solve it I guess. Audiobah has turn-off thump too.
Same issue here as well, but thumps also on power off :sigh: Although it does sound excellent, also well made, but those thumps are not good. I tried with 12V brick via DC extension cable with ON/OFF switch, and same 6N3 pre/buffer but no remedy. Will write to Sure and ask for a solution, their product manual says nothing about additional connections on pcb, and I found quite odd those markings - no left/right but CH1,2 and Out1,2, where 1 stands for Left and 2 for Right channel, and RCA's are both black. hmm not so user friendly IMHO
So far Audiobah's green is the Leader of the gang, to me! :yes:
This great thread, together with another AK thread on the CNC phono preamp got me inspired.
I got a black/blue 3116, etched a CNC phono PCB and started a little project. It will have a passive pre (except for the phono stage), a 4-way selector switch, volume and balance.
To round it up, here's the enclosure with the lid on:
Not only that Audiobah's board is pop/thumps FREE but it does sound the best, or better than YJ black or red! Those two need hell of mods (black esp.) to come to the quality of sound reproductions of A. green - untouched! That is also approved by others, but that's what I have learned so far as well. I have replaced two crucial type of parts on YJ black and it's still not in the league of the little A. green, although it's also pop/thump free, and cooler now!I thought the whole thing about the Audiobah board was no pop or thump?
Yes, certainly I will :thmbsp: but will not expect the answer before next Monday?Let me know if the Sure guys have any advice on this, Jadran. I may try replacing the pot on my passive pre that does not attenuate fully. A better pot solved this on my black board build - I used an alps blue velvet 50k log pot there. Will also try a lower power supply - a 12v/5a supply is on order.
Looking very nice and along the lines of what I am looking to achieve, wanting to get it as small as possible, but have a couple more boards to position internally ..... a couple of ?'s if I may
Is the switch a 12mm or 16mm ?
Is the case a 2205 (220mm * 191mm * 52mm) ?
Thank you
natger;8012792[B said:]Audiobah green has thump when power goes off[/B] and outputfilter is designed for ~6.5 ohm speakers.
What I have tried now is connecting the 3110 directly to the source - H/K DAC, that receives signal from the PC/Jet audio soft., so no volume pot between or any preamp., and as image shows volume is controlled by the software and level is at min. Sound is great, and now the thump appears at switching off the board, even with vol. level all way down. Could be that switch on the cord, but have no time neither patience to mess around with it and also need additional parts/connectors to solder on the board for other types of PSU and diff. switches.
Will see what (and if) SURE has to recommend.
I tried to simulate your experience by taking my 3 tube 6N3 preamp out of the system, and doing as you did. The amp connected to the source- Schiit Modi USB dac; signal from PC/Pandora software. No volume pot, software volume.
I left the volume at listening levels instead of turning it down when turning on my Astron PS which is not instantaneous as cap(s) charge for a second or 2. No noise at all, just loud music. I tried the same with turn-off. Again, the charged caps keep it running a few seconds, but no noise what so ever?
I thought maybe the delayed on/off of the Astron PS was helping hide the thump you hear, so I tried my Indeed 12V PS brick switched by a multi-outlet 120v box. Same results...silent. Soo...I tried my 24V brick which I plugged directly into the wall receptacle, again nothing heard. I am driving X-LS Encore 8 ohm speakers. The very tiny tic I have occasionally heard in the past on turn-on only, I attribute to the Pre-amp, as it is completely gone without it in the system.
I feel bad you guys are having issues with a board I recommended. I still feel it's the best board I have tried yet, and it betters the TPA 3116 YJ Blue/black board that has not been heavily modded. The Astron PS really improves it more, as does the 3 tube pre-amp, but it still sounds great with just the software controlling volume.
Has anybody received their Sure 3116 amp yet?
