gusten
Addicted Member
I am absolutely correct.
"For analysis of the mechanical
requirements of the pickup, the audio spectrum may be
divided into three parts: the amplitude-limited region (20
Hz to approximately 1000 Hz), the velocity-limited region
(approximately 1000 to 4000 Hz), and the acceleration limited region (above 4000 Hz). In the amplitude-limited
region, stiffness of the bearing element limits trackability;
therefore the bearing should be highly compliant. In the
velocity-limited region, damping should be low; and in the
acceleration-limited region (near resonance), a large
amount of damping is required to reduce the mechanical
impedance. Additional bearing stiffness may also be
desirable to raise the stylus resonance above 20 kHz."
The level is usually highest between 100-800Hz, this also means that needle velocity is highest, even if we take into account the RIAA compensation.
gusten
