It’s fine and a good fit for the table but there’s better.
Was the M97xe any good? I just purchased one for my Garrard. I may do a different cartridge for my Dual changer, however. The Dual has the M44c on it, and while its a fair cartridge, I will want to upgrade it once the Garrard gets fitted with its new cartridge.
Which Dual changer do you have? The M44C is a good sounding and tracking cartridge and there are several stylus options for it. If it has the original N44C stylus with the light blue grip, it may be too stiff for your tone-arm. Recommended tracking force for the N44C is 3 to 5 grams so it's better suited to heavy tone-arms. The best stylus I have found for the M44 series cartridges is the N44E, it tracks between 1.5 and 4 grams which makes it compatible with most of the tone-arms out there.
https://www.jico-stylus.com/product_info.php?cPath=18&products_id=1012
The M44 cartridge with a N44E or N44-7 stylus will be louder and livelier than the M97xE.
Its the CS 1246. So you say the M44C that's on it is ok??? It was a well kept unit, so its last owner probably did a lot for it. Maybe I'll try a different stylus before getting another cartridge. I noticed that the Pickering on my Garrard (before I sent it out for service) had a slight hum on one side (it might not be the cartridge but the wiring) yet sounded a tad better IMO. I do like the performance of my Dual, however. No hum, quiet and it has good sound. I may try your suggestions. Thanks.
Edit: It has the light green stylus on it....lemme see I might have a pic of it...
Ok Gotcha. Oh well....I may stay put just a little while. I don't think I'll get a shure this time for it. I've got a couple of models I'm looking at. What about Grado Black 2? I hear good and bad things about it. BTW the 1246 is a changer, but it is sleeker than the traditional changers from the earlier '70s, and the arm is described as an ultra low mass. Its a fully automatic belt drive TT.When you said "changer" I assumed one of the earlier idlers which is what the M44C works best in. I'd go with a more modern cartridge for the 1246, something that tracks in the 1 to 2 gram range. Save the M44C for when you come into a vintage idler.
I’m still happy with the Rega Planar 3 that I bought new in ‘87. I’d recommend a low-mileage used one (either Planar 2 or 3) to anyone. They’re a time proven, simple minimalist table that isn’t fussy about setup, and can sound really impressive with some mods. Mine has been through four cartridges in 30 years (1 MM and 3 MC’s), and everything has sounded good on it. I have several other tables as well, but the Rega is a faithful old friend. ^_^
It’s always been my understanding that the most important aspect of a turntable is the cartridge.[/QUOTE]
