Hi, I have been struggling to get genuine uPA68H for my Sansui B2101. Purchased from eBay $2-20 each but all are fake.
I will really appreciate your support.
Thanks
Ebay seller ceitron (Consolidated Electronics, a USA firm) can be trusted, but you might want to research whether there's any difference between the uPA68HA that they're offering and the non-"A" part.
Or check littlediode.com in the UK, also trustworthy but expensive.
In addition to the option suggested above, you could build a small addaptor and use a pair of 2SK209BL. Thermal tracking will not be as good, but this type of discrete solution has been used often and it works. There are addaptors out there on ebay or you can make it yourself by the toner transfer method. I attach a pdf of a file that could be used to make one.
EDIT. I forgot to mirror the pattern so that when it is ironed to transfer the toner it comes out right. I reattached the file with the mirrored pattern. It needs to be laser printed onto toner transfer paper, but magazine paper may also work.
