Some interesting stuff about the different versions of the vacuum rods, the diameter of the tube varies .015". The later rods are pinned, and need to be turned down in a lathe to fit the holder. Pay attention to the clearance the rod has going into the holder, it varies greatly. The clearance inside of the holder determines the suction through the rod. About half the rod should be exposed in the holder. If it is shoved in too far, it causes too much restriction. If it is not in far enough, the rod will not seat well enough, and will not have enough restriction. That could cause damage to the vacuum motor by letting liquid in from the tank.
Could you please clarify a few things about this statement? I have definitely noticed the tubes do not fit well, but what do you mean by "pinned"? I see they have a slot at the end that goes into the holder - is that what you mean? Should some/all/half of that slot be outside of the housing?
Thanks for any clarification you might give!
I hope you don't mind me chiming in, and responding in place of the original poster?
I believe the point he is trying to make, and what he speaks of, is how the clear acrylic vacuum wand slips into the hole of the vertical wand tower.
While I have yet to break a clear acrylic wand, and thus need to replace it with a new one, to notice any manufacturing differences, it sould like the original poster has.
That hypothetically, a brand new wand bought from VPI, or their dealer network now seems to fit differently into a Wand Holder that is a few years old> This, I'm not sure of, but if specs, or the way they are made has changed, then yes, I can see this being a possible problem.
I believe some years ago, The VPI black delrin wand towers did not have a alignment-locating pin, which helps to properly align the clear acrylic wand in the hole when inserting. In any case, the fit is not so highly precise, that some fine tuning of the wand slot in regards to the surface of the record is slightly tuneable, and adjustable.
I understand, that the slot itself is not supposed to be exactly perpendicular to the record's surface, but canted ever so slightly, perhaps no more than a degree or so, to the rear of the machine. This aids fluid flow into the wand, and thus better fluid pickup.
Now, if one should find when they insert a new wand into the tower, and the locating slot in the wand is still exposed after seating, then yes, this is a problem, and will cause a loss of vacuum pressure. That sort of tells me there is not a proper fit then.
VPI is the sort of company though, if any problems such as this are ever experienced, I have little doubt, that regardless of time, even if you've had the machine for ten years, contact them, and they will somehow make everything right, no charge. They like happy customers.
VPI has recently gone through some very recent sorrows in the family, with the passing of Co-Owner, Sheila Weisfield, Harry's Wife. Mark
