Thanks for those tips Mark, I never would have thought of pulling the wand for drying.
Oh and I got a new one. I used it for about a dozen records today. Things are working great. Only two comments so far.
1. I am using fluid fast! I was supposed to get the one gallon concentrate mix with the unit as the description said so. But there was only a 8oz premix in the box which the seller said was the concentrate. I contacted VPI and they confirmed that is premixed, not concentrate. So I am thru half the bottle allready.
I can order the mix but it will take a bit to get here. Is there an alternative thing I can pick up at the store locally and mix with distilled water?
2. I think there is cross contaminating from the clean side when I flip it to do the other side. I am pre brushing before using the 16.5 and putting it in a clean inner sleeve afterwards but I'd hate to think I am blowing it by flipping the disc with the dirty side contact.
Maybe I should pick up a pair of mats to alternate or am I being anal?
Hello MBob, I'm going to try addressing all your questions, and give my opinions FWIW.
Firstly, no, you are not being anal, and this is a real issue with the VPI 16.5, with its Cork Mat. I'm of course not the only one who's recognized this shortcoming, it was probably a more inexpensive way for VPI to produce such a machine, and try to keep it affordable for the masses.
Some buy another spare Cork Mat, some use Shelf Liner, or other items, to place the clean side onto. The Cork Mat is hard to clean, one cannot easily see dirt-dust on it, and the dirtier the records, the faster it will get dirty.
I've totally eliminated my Cork Mat altogether, and have installed a Neoprene Rubber Mat, permanently Glued (contact cement) to a custom Acrylic Platter, cloned from the original Platter's dimensions. This Mat material, Shore A hardness of 60, can be gotten from places like McMaster-Carr Supply.I recommend a Shore A Hardness of between 40-60 as being ideal for a Mat.
Mc-Master-Carr does sell the Neoprene Sheet with Adhesive Backing, but I bought this, and found it didn't actually stick too well. 1/16: thickness should work fine, I used an empty .38 caliber cartridge case as a punch, sanding the edge with a bit of sandpaper to sharpen the case edge, then used that to punch the holes for the spindle, and the three holes for the three screws that hold the Platter on. You'll want those holes in case you ever need to gain access to the Platter Motor, in which the Platter must come off.
My wisest recommendation as to what to do about cleaning fluids, is wait.
I wouldn't use lesser products, then find the job hasn;t been done as good, then feel a need to have to go back, and re-clean all those 1/2 clean records. That's really a waste of time, and money. Do it right the first time.
As for Alcohol. and adding it to a manufactured cleaner, it might help? In truth, that is probably correct, that the Alcohol will act as a surfactant, making the water more "wet", Many people wrongly assume that 98% Alcohol is 98% alcohol, and 2% water, when that actually is not the case. That 2% also consists of other things, such as impurities. 98% Alcohol from Walgreens is not Laboratory Grade, and usually the best cleaners on the market do use better than this, "If" they contain alcohol. Many stray from Alcohol on theie records, but the proper types, in the proper concentrations, left for a short period on the record isn't detrimental.
Experience will then teach you in time, pretty much exactly how much fluids you need to use when cleaning. I use enough to insure the record groove is covered, I apply, spread with a MoFi Brush Pad, let sit a few minutes, insure those fluids don;t dry on the record, then begin a very gentle scrub, scrubbing in both directions following the groove, do a small section of the record at a time, rotate the platter slightly, then continue on, till the entire record has been scrubbed. Then vacuum off.
The wait would not be long, depending who you buy the fluids from. Who I get mine from, could probably have you your fluids in 2-4 days average. That's not too long to wait. Mark
