in my quest to educate myself about the design and function of these tweeters, i've been trying to seek out people in the know. i always prefer facts to speculation, and first hand info to hearsay. you all know i solicited jay's contributing to this thread. since jay is focusing on other things, i contacted john strohbeen at ohm acoustics, but he knew nothing of the tweeters as they were from before his involvement with ohm. i learned marty gersten (who worked with lincoln walsh, and founded ohm acoustics after leaving rectilinear) was involved with developing the production tweeters, but he is dead, as is bruce zayed (ohm's chief engineer at the time). lincoln walsh did experimental work on tweeters, but he has also long since passed. no doubt arnie nudell could shed considerable light on the subject, but i haven't gotten past his firewall yet in terms of a dialog.
i have been having some email conversations with dale harder from HHR exotic, who is the most knowledgeable person i've found on the subject. dale comes from a background in lasers but, (like arnie nudell, whos' background was also in lasers) his passion is speakers. as some may know, dale's speaker company makes its own advanced design walsh speakers (really nice btw, i recommend you check them out) and he's done his homework on all things walsh. he was a good friend of marty gersten, and was also able to interview bruce zayed, and he has gleaned much info about the infinity walsh tweeters. he has been very generous with his time and knowledge, and very patient with my questioning. i'll save you all the back and forth of our emails and just present info specifically relating to the infinity walsh tweeters. these are dale's responses edited and condensed from the quite drawn out question and answer sessions, which frequently veered off on tangents related to walsh drivers (but were not always specific to the infinity tweeters). these comments are specific to the infinity tweeters. the bracketed bits i added to maintain context.
dale's words:
Repairing these drivers [infinity walsh tweeters] is a very simple matter…, really. The beauty of these drivers is that they worked without a great deal of Voodoo Magic. It was simply an understanding of how and why they performed. For what it is worth we [HHR] can re-manufacture them. However, since [your thread] is a DIY thread and forum, most probably want to try it for themselves. I realize there are many out there that have some skill.
Marty Gersten and Ohm Acoustics actually developed the [production] tweeters, but licensed them to Infinity. Most of the prior work had been done by Lincoln Walsh himself. In fact, some of his units reportedly went as high as 40KHz. They are Transmission Line Drivers and not Dynamic Drivers. They do not move air like a dynamic speaker. The are more akin to the Bending Wave driver. The key is to have a very thin cone material with low mass, but extremely high rigidity. Low mass for ease of acceleration. Rigidity to hold its form, and high density to allow for very fast propagation through the cone material. In the case of the Infinity tweeter, propagation speed is 3 to 4 times the speed of sound in air (1,128 ft/sec).
The cone angle is a bit of math, but suffice it to say the angle is chosen to produce a cylindrical wave front that is perfectly vertical in nature emanating from the cone. it also, assures time and phase coherence. I know that the original tweeters used aluminum foil off the shelf. Some was diamond foil and some was scribed. The purpose of the diamond or the scribing was to stiffen the foil, since most Aluminum foil off the shelf has been annealed and is very soft. this does not bode well for the bending wave driver and can cause the cone to fold up or crush under high loads. The production drivers were very simple consisting of one layer of foil with about .0015" to .002" thickness. X-max [linear cone excursion] was on the order of + / – .004" without damage.
Remember, back in the 70's aluminum was readily available off the shelf and was relatively low priced. All the wonderful tempered and alloyed aluminum and foils we have today were not readily available,...and since this was the beginning of this type of driver, even the designers did not know what to use. It was mostly trial and error. Lincoln Walsh himself, investigated, papers, felted paper, aluminum, plastic, and various other materials. Also, looking at the tweeter, even though it was relatively soft material, since it could [economically] be stiffened by mechanical means and it did not have to support anything, it worked reasonably well.
Many [dampening] "goo's" consisting of silicone grease, oil, rubber and felt were tried including a double layer cone with damping between the layers. There never was any "goo" used in the production drivers.
The center posts inside the tweeter were for strength to prevent the cone from folding over or damage if touched, since that had very little actual movement capability. They were non-magnetic and lightweight. [The aluminum tube's] resonance was also very high. I am not convinced that they had thought this out that far at the time. Necessity dictated simply grabbing what was available and low cost at the time. [The supports were] hard epoxied to the VC and the spider was simply an embossed foil to provide some movement.
The open cell foam acted to damp the cone from ringing, provide structural support to the center tube and to help with the air/metal interface where the sound hopefully was absorbed at the annulus of the cone. If sound is not absorbed here, when it reaches the end of the cone and perceives the air/metal interface, physics demands that the propagating wave be reflected back down the cone 180 degrees out of phase. The 3/4" foam plug at the top was glued to the cone at the terminus and it was to provide the damping and absorption of the wave at the air/metal interface and prevent reflection of the wave back into the cone. It was also a strengthening agent to bond the cone to the center support.
The density of the foam does play a role and this is why in our work with all Walsh speakers we tell people, you can't just grab any old thing and throw it in. The foam that was used in the tweeters was an open cell foam, charcoal grey in color and the density of the foam was uniform. Off the shelf foams do not work as well. Some off the shelf foam has a very randomized cell structure with lots of air voids and this foam does not work as well. This leads to break-up and wave cancellation/reinforcement giving the speaker a very muffled or hollow sound. Even muddy, or veiled.
there you go. a few more bits of info into the mix. conversations continue. i'll post relevant additions as they present themselves.
