Starting to rehab a newly acquired set of W70Es and some pics of the process and observations on the physical aspects of things. Also, a physical comparison to the W70'a' and W60DMark II. Wax markings on the 60DII woofer cone back were 12/1969 and the E were 11/1970 so produced about 11 months apart. E's also marked with "p/GB" and u/GB. Hopefully GB means Gilbert Briggs touched these!
Of course, it could actually say "p/68" for all I know.
New caps in on the xover and ready to go into the speakers shown below. The existing generic ones that were in it upon acquisition are just below for comparison. 2x3uf for the 6uf and 2x4uf for the 8uf cap so that I have the precise matches to factory and not .2 off, plus a little 3M automotive body panel tape to keep any rattles/vibrations/movement at bay.
Many thanks to forum member infullview for helping me get the wiring sorted.
Having had the W70 'a' ported all alnico 3 ways and a pair of W60D Mark IIs previously, my initial impressions are that the build quality is substantially less in the W70s.
Case in point, the prior generation of W70Ds were 26lbs more per pair. The W70Es weigh only 1 more pound than the W60Es, so I suspect the W60E may not have been subject to this same change.
There are no similarities in any of the drivers between the D Mark II and the E model I('ve) own(ed). 12" speaker, which appears to have the same 9.5lb magnet as the 15" measured closer to 13" than 12" and the 15" woofer measures more like 14" so I don't think there's that much of a difference. Perhaps a 1.5" or 2" cone difference, as opposed to the nominal 3" as indicated by the advertised nominal sizes. The wonderful fiberglass or whatever green cloth surrounds from the D Mark II have been replaced with rubber on the 15" E woofer, which appears to be soft and pliable, despite the age.
Other things that stand out:
- Completely different mid-range than the 60DII, which was sublime. I'll see how these are in comparison.
- Tweeter is different also. Prior 60D MII was round, and more robust, E is square and smaller. Plastic covers on tweeters are a bit different and plating is much higher quality on the DMII.
- The DMII cabinet, when rapped sounded very nice and dead, like a 1/4" sheet of plywood glued to concrete. Tapping on the W70E gives a more hollow, resonant sound, particularly on the back. The side and top walls are noticeably thinner, also. The back wall is some sort of MDF or particle board, instead of the laminated plywood encapsulating the sand, which when stained looked great. The E is not nearly as well built as the DMII, but is not bad by any means. I think a sand filled back would have been a great addition though, but not sure if that's an improvement in practice.
- The woofer magnet on the 12" DMII is 'chunkier' and the plating finish is more like a mirror, while the E is thinner, unfinished, lots of machine marks and many square edges of the metal plates rounded off from not having clean cuts like the DMII.
- The wire gage in the inductors for the E appear to be thinner than the DMII and far thinner than the W70'a'
- W70'a' had PIO oil caps (AA british military markings) and the DMII and E have the minerva electrolytic non polar caps.
- W70'a' had all alnico drivers as evidenced by the red magnets. The DMII and E are all ferrite drivers.
- The W70'a' had air core inductors vs. ferrite cores for the DMII and E
- The 60DMII has nice square cut rockwool (or some other material) fit and inset perfectly into furring strips for each panel, except the front baffle. The Es have a loose 'blanket' of insulation material stuffed in. Very shabby looking compared the DMIIs, but hopefully not something that impacts sound.
- The removable items like back, drivers, etc. on the DMIIs have maroon felt on the mating surfaces, which seems like it would help ensure a good seal and eliminate any vibrations. The E doesn't have anything like this with wood on wood mating surfaces and a hard gasket for the woofer basket.
- edit... The 60DMarkII adjustment pot had a removeable black back cover, to allow easy access for cleaning. The E pots can be taken apart with some metal tabs but would require a dissassembly. Hopefully there's a hole big enough on the case to spray in some contact cleaner and lube with a nozzle tube.
Overall, the 70E feels and looks like a solid notch below the D Mark II in fit and finish and certainly in the cabinet construction. If these physical aspects represent part of the switch from hifi to midfi in the early 70s, this is clearly manifested in a comparison of the two.
The woofer seems to share the same cast construction, and the tweeter is similar, perhaps a bit smaller on the magnet. The mid, however, physical design wise is not nearly as well built. Of the 3 the W70'a' drivers were the most robust. The supertweeter 3 being far larger than either of the E or Mark II models purple dome tweeters. The DMII is round and the E is square for the tweeters.
Will be hooked up to a Fisher 500B and Dual 1229Q turntable, which had great synergy with the D Mark IIs and really had a spooky real 'breath of life' sound for vocals. The W70'a' sounded OK, but more like a rock speaker. Typical ported bass sound (a hollowness, like a mid fi home theatre sub), but could hit deeper than the 60DMK IIs, and with much less finesse. Also, the mids not nearly as lush or even forward as the 60DMIIs and overall refinement and detail a bit lacking for the 70'a' which I quickly got rid of.
Given this model has a totally different build and crossover configuration than my previous models, I'm not sure what to expect, but looking forward to hearing them fully restored and hoping they have the same magic as the DMIIs.
Hopefully they also sound as good and aren't a step back. Will report back after the installation and listening sessions.
