Wharfedale Owners Thread
Hello, I am an absolute newbie, have never refurbished nor done any work with old audio equipment before. I do have some experience working with electrical equipment from my education though. Anyways, a while ago my partner and I inherited old speakers (I believe they are Wharfedale W60s) from my partners Grandma. Right now we are using them as end tables in our living room, but it has always been in the back of my mind that I would like to eventually use them as real speakers again some day, which has brought me here! I don't really have any idea of where to start though. So I guess I am just desperately looking for any kind of resource or guide that will get me started towards making these speakers work again. Thanks for any and all advice or help you might be able to give me.
Hi Bryce, welcome to AudioKarma. There were a number of different versions of the W60. The first place to start is to identify which ones you have. The earliest of them are a two way design with a tuned port. Can you take more pictures of the back and specifically the speaker terminal plate on the back. Early W60s also had a sand filled back that helped to deaden box resonance. You can also date these as woofers often had the date they were installed hand written on the back of the cone. If you intend to put these back in service, there are many on this site that can assist you with the proper procedures. If you have an Ohm meter, and soldering skills, you might want to see if all your speaker components are good. You would detach one lead of the speaker being tested and check each one for continuity (should all be around 6 Ohms). Reading OK on the Ohm meter does not guarantee the speaker is "good". You should also hook them back up and do a low level sound check to make sure nothing is buzzing or rubbing. Next step is to rebuild the crossovers with new capacitors.
Also, one quick precaution.
If, after you get the unit open, you notice any whitish/yellow powdery residue on any parts inside the speaker, don't touch it. It could be cadmium and you don't want this getting in your body. Take care to handle properly and I'm not an expert but do your own research. Hopefully you won't see any, but I did on a pair of W60s on a few small parts inside the speakers.
Don't let that put you off getting started though, just wanted to make sure you were aware, in case you open the unit up, so that you don't touch it with your bare fingers or otherwise transfer it to your body.
Good luck with the restoration and the collective group have helped me restore 3 Wharfedales to date, so you're in good hands.
ps... try pulling forward on that wooden bar that crosses the speaker horizontally. You might find that the speaker cover comes off easily and is held in by velcro. Don't pull too hard, but enough to pull away 4-5 velcro strips, as some models may have that bar only for decorative purposes.
See the 4:23 mark in this video and 2:39 of the same video for examples:
Wish I understood the language he's speaking, as he has a ton of Wharfedale videos and in some videos, you can really see how different some of the same models, including versions are constructed. Different cabinets, speakers, configurations, finishes and levels of quality. Really neat stuff.
Just thought I'd put a note as to where I ended up with the 70Es.
After removing and re-installing the woofer about 5x over the past week, I've finally landed in a place where I'm very happy with the sound, trying different combinations of the existing fiberglass placement and amounts and the kilmat on interior surfaces.
  • Being happy with the sound, I decided to go full tilt and put kilmat on the inside floor, sides and top, along with 4" square on the back of the midrange tube, which is capped with a thin cardboard cap on the end is air tight, as pushing on this 'drum skin' pushes the mirange out.
  • This sounded amazing on good recordings, but on much of my vinyl, too much of the bass extension was being robbed and I really needed to trim the mids/highs down on those to get a good balance and also goose the bass knob tone control far from flat as well as trim back the treble tone control. Also, the focused bass pressure felt more fatiguing.
  • Removing pieces one at a time and trying them out, I landed with the original 2 on the exterior back and bottom and one half sheet on the interior top as well as a 4" square on the back of the midrange. The combination with no bottom and one side damped also sounded pretty good. I erred on the side of more bass extension, though I might try thin 1/4 sheet sized strips along the front half (closer to baffle) of the sides after listening a few more days/weeks.
  • pro-tip... if you're taking these in and out many times like I had to, adhering the cardboard gasket to either the speaker or the cabinet with a couple of dabs of very thin adhesive or 2 sided tape makes this process much easier, as the hard gasket has a habit of moving around quite a bit, making alignment a bit of a chore.
One other note, the tygan grill covers responded pretty well to a 15 second hit with a power washer, a light scrub with a bristle brush and immediately drying with a towel. Much improved as a lot of brown water and dust having been removed from the grills. Not being cloth, they didn't hold much water and didn't fray from the scrubbing. A few seconds of water didn't hurt the old pressboard at all.
Here's a before after. The darker one on the right was cleaned and left for 48hrs to completely dry over a hot air vent.
The 'holes' in the frame are much less apparent if you compare the below to the image above in post # 1787.
Here's some poplar grill frames I made up that are 'friction fit' perfect and square, so will need a very thin cloth or have to sand a bit, but for now the stock grills are at least far more listenable and as side benefits the dust removal also made the 3d texture much sharper and overall more even tone. Also, you can see the kilmat removed during the 'testing' period. Wish I had the where-with-all to understand and measure Qtc, or other more data driven or scientific methods, but I adjusted to my tastes, given my level of knowledge and equipment.
Found just the right size neodymium magnets for the frames. Will put one in each corner, horizontally and glue on the plastic spacers they came with to make getting them off easier. Might have to add a small handle or tab on the front of the grills to make taking it on/off easier as the magnets are very strong. As an example, I am able suspend a small hammer from a hidden screw-head in the drywall with one of these.
Also added some banana plugs in line with the knobs with small metal plate that gets screwed on, using the existing terminals and has a 2nd set of holes bolting on the 'supplemental' terminals.
Just need to add some knobs so I can see and possibly mark the settings, like I did on my w60d and I'm calling these done for now.
Hi, sorry for the late reply, but thanks so much for all the advice! This is some great advice on first steps, also thanks for the cadmium heads up, I'll be sure to keep that in mind. I've attached two more pictures of the speakers (sorry for the poor picture quality, my phone camera is a bit smashed) showing the outside back of the cabinets. Let me know if you want to see anything else about the speakers, I'm happy to share.
Hi Bryce,
Your first order of business will be to get those backs off.
However, it looks like you'll need to make sure the crossover panel in the center doesn't prevent opening the back due to connected wires.
To avoid that, you'll need to first remove the 4 screws (looks like 3 screws and one nut) in the center of the panel in the cutout. Once that's loose, you can remove the 10 screws around the perimeter and you may have to put the speaker on its back and tap the sides or gently pry an edge to coax it out. It does look like the back has been off though, as the original Wharfedale screws I've seen have always been flathead and heavily oxidized and gray or rusted, while yours look shiny and not flathead, so hopefully comes out easy.
Once the backs are off and free of the speakers, you'll should be able to remove the board where the speakers connect and looks like this... (not my pics)
Once you take yours out, if you want to test the speakers, you can disconnect the speaker leads and test each speaker one at a time with an ohm meter or the resistance measuring setting on your multi-meter. If they all have a reading, that's a good sign. If any display an open circuit, then you might have speakers that are bad but hopefully can be refreshed, repaired or replaced.
Also, if you take pictures of your little board, the folks on here can help you identify what parts to refresh. I suspect that you might have paper in oil capacitors in yours, being an early one, so may look more like square metal boxes, sometimes grey or olive green with the AA British military markings.
A picture of the inside and particularly the speakers might help too, so folks can see if you've got the original speakers and if they are in good physical condition or may need rebuild or refreshing. If you see red tape around the magnets of the speakers, and they are Wharfedales, then they are alnico, instead of ferrite magnets. Just a factoid that you won't likely need.
(this board, as shown in the example above is the crossover - it splits the signal from your stereo into different frequency ranges appropriate for each speaker)
(the parts that are usually replaced are the electrolytic capacitors which are on this crossover, as they degrade with time)
(in the example above, the capacitor is the red part)
Hello All, Do any forum members know of anywhere I can buy NOS or a good copy of the speaker cloth used in the W2/W3 etc range from the late 50's. early 60's? Ideally in the UK but poss from USA or elsewhere.
For those who have not worked with it, it has quite a stiff, self-supporting quality to it, obviously some sort of resin or plastic weave in the cloth and a tweed/checkered/sawtooth appearance. On these models the cloth is not pulled tight over the baffle and fastened behind, it is glued to the front so there is no way to stretch it smooth, it is more like a plastic grille than a cloth really.
I have just managed to pick up my holy grail. a first production run set of W2's (matched pair with alnico 12" and Super 5 drivers all in top condition!) Yey! They sound awesome, need a little TLC and nice clean grille cloth, hence the request. Thanks,
If you are looking to keep the material original, I believe it is 'Tygan,' from reviewing the Wharfedale cabinet making handbooks. Same stuff was used on the LS3/5a speakers and Range Rover seats (https://www.exmoortrim.co.uk/blog/post/tygan), if that helps.
Black is available here: https://www.thomannmusic.com/adam_hall_0715.htm
For more vintage colors, these folks appear to have what looks like salvaged pieces here:
If you don't have to have Tygan, these guys have vinyl coated fiberglass fabric, with the vintage patterns, if you scroll down to the bottom.
eBay often has these also.
Just fyi, the materal, being water resistant will take a good scrubbing with a bristle brush, soap and water, if you can keep the water off the pressed frames, or at least minimize it. See my results in post #1797
Thanks for your reply, yes I believe you are right and thanks again for the links. Looks like you have been where i am now.
I can't clean the material, the fronts are not removable, and anyway, one of the fronts has some damage. The Briggs book on cabinets was an interesting read too, using an electric heater to heat shrink the fabric! Makes sense, but I bet it takes a little practice to get an even finish!
There is a single 10” Wharfedale 10” 2507 woofer that is used in the W45. This is the square magnet speaker they don’t become available very often for this fairly rare speaker. I mention the magnet because it’s crossover is slightly different, it has 2 NPE’s not three like the earlier round magnet woofers I have spares for my pair so I don't need it. The posted price is a fair one. It is on eBay. He also has a tweeter he is posting this is the same one used on the W25, W35, and W45
Just a PSA for Wharfedale Owners...
The Marshall knobs with set screws from the tube depot are a perfect fit for the pots on WD speakers. You can actually see where they are set vs. rotating them to the ends of their range and guessing. Really helps with fine tuning for trying to a/b impacts.
Opening is 9mm and there's a brass set screw (flathead).
Pack of 10 was less than $10 delivered, btw.
top, bottom and side views
Because of the recess blocking the set screw a bit, to install, I kept tightening the set screw and pushing on until I felt a bit or resistance, and then did a 1/8th turn and it pushed on very snugly and tapped in lightly with a watch hammer. They are snug and not going anywhere!
If you have small screwdriver you want to bend or just use a small bit from a kit, that would work just fine. I was in a hurry and so did it the ape way.
Range of motion from low to high is from 7pm on the dial (lowest setting) to 5pm on the dial (highest setting)
When installing if you point the line at the 7pm and the dial turned all the way down, you will get the midpoint centered perfectly at the top, which makes it easy to understand visually where, relative to the range the speakers are set.
These are straight up for the photo, but I have them bot set around 2pm to 3pm.
Excellent never thought about doing this. I have been trying to find a source for the barrel type thump nuts used on the speaker posts in the late 1960s.
I have a pair of W70Ds recapped with Russian PIO caps. Nice sounding speakers, but they can't compete with my Zenith 49CZ852s in open baffles.
Hello, fellow Wharfedale owners. I am a new owner of a lovely pair of W90c's that I found locally. They are fantastic sounding speakers and in pretty good shape (one cabinet has water damage to the sides). The one woofer in that cabinet (without the polystyrene) is rubbing on the coil or something along those lines, I can reproduce it if I manually move the cone. I flipped it 180 degrees and reinstalled but it's still rubbing. The strange thing to me is that when it's laying on its back, it does not rub at all.
I am not super well versed in this stuff (if you didn't figure that out from the first paragraph) and don't want to do surgery on this one without having a backup. I found a woofer for sale from another W90 that looks the same, with a round magnet on the back instead of square. My concern with the possible replacement is that it measures at 5ohms where mine measures 6ohms. Is that 1ohm difference going to be an issue?
I appreciate any advice you may have. Thanks!
Great score! I love mine, but it has been years since I had them opened up, cloth surrounds, right? Does the surround look tired? I would measure w digital calipers the distance from cone to frame lip to determine if it is off center. If it is, I would consider correcting it, opposed to buying another woofer. Remove dust dome w exacto knife, release outer edge of surround, shim around magnet, glue back surround. Reset done w glue, then treat all woofer surrounds w cloth surround goo.
the 1 ohm difference may not make a difference, but I'd try letting it either lay on it's back for a bit, or let it sit a few days due to being flipped 180 degrees to let it "reseat" itself. I'm no expert, and many on here will give better advice. I don't know if the surround goo or redoping was used on these or not. I have a pair of these and the W70-D's. I'd post pics of your driver and the replacement driver as well. One may be a ceramic magnet, and the other may not be.
ducati2 - Yep, cloth surrounds on the woofers. They seem springy enough but they could very well be tired.
JFRACE - I will definitely let it sit for a few days to see if that helps. I don't see any signs of any doping being used (I can see through the cloth surround as opposed to it being impregnated with something)
My driver is the pic below. The seller took down the pics of the replacement but it looks identical with the round magnet on the back instead of the square one. Thanks for replying, guys!!
Edit: I'll take better pics when I have both drivers side by side
Before you give up on the original woofer, maybe try playing the speaker faced down, playing at low volumes for a few days. On the tip of an AK'er, I did the same (2 days, low volume but loudness on, bass up) with woofer on a pair of W60Ds and, surprisingly, it worked.
Sam088661 - I will absolutely give that a try, that's a pretty interesting idea. I'll have to dig out a spare receiver. I found that one of the mids in the same cabinet is doing the same - I reckon it can't hurt to try with that one also. Thanks!
