Wharfedale Owners Thread
Wharfedale W60E Crossover – need help!
I just got pair of Wharfedale 60E speakers from Craigslist. They are later production of 1972. Don’t like how they sound, especially lacking of bass.
I decided to recap it but was puzzled by how crossover looks like.
I am really don’t know how it’s work, but my soldering skills should be enough to mimic existing one. When I open speakers I realized someone already done some work before. Crossovers are look different then ones I see on internet. Someone messed with l-pad connections.
Maybe it was an improvement but I’d like to bring speakers to its original state and maybe improve overall performance.
I just wonder if someone have original schematic for W60E or pictures how crossover should look originally. Or maybe pictures of your crossover before or after you recap yours? Really need help with this.
It's hard to tell from your pictures, but it looks like at least one of the 50 Ohm wire wound potentometers is unhooked. The center lug should go to the mid and tweeter. On most designs of this time, there is also a 3.3 Ohm resister in series from the center lug on the pot to the mid range. Look on page 55 of this thread for my W70E crossover schematics. They are essentially the same as the W60E (same year 1972).
Thank you infullview!
Actually on both potentiometers center lugs not connected to any wire. Only one 25 Ohm resistor is there. I will use your schematics and draw how crossover is now.
Do I have to check my drivers impedance?
You should check them for continuity, and they should all read around 6 Ohms (DC resistance). Do you W60E's have the original purple dome tweeters?
Forgot to mention, you need to check continuity of the pot's - they should read 50 Ohms across the two outer legs (you may want to unhook one leg to test). That may be why they added the resistors.
Sorry infullview!
Just want to pick your brain again.
I draw a little schematic of crossover based on what I discover in my speakers, compare to your diagram of W70E crossover.
Discrepancy what I see is connection of woofer line 4mF cap to tweeter line and 25 Ohm resistor between tweeter and mid range.
Plus, missing 3.3 ohm resistor.
I just want to ask if it's OK to re-solder mine the same way as yours.
Thank you!
Sorry infullview!
Thank you!
Yes. Your crossover should be the same as for the W70E. Not sure why someone added that 25 Ohm resistor, but it clearly has no place and has a tolerance of 10% which doesn't cut it for crossover purposes. You should get 5 or 10 watt 3.3 Ohm with a 1-2% tolerance (part-express has these). Check the 50 Ohm potentiometers to see if they're good. These are not easy to find and you will have to order NOS on e-bay if they are not OK. I hope you understand that all lines marked "-" go to the negative terminal and all lines marked "+" go to the positive terminal on my drawing. They are just drawn separately to make the diagram more clear.
This is a stock system. Someone has tabbed the wiring to get things back together. It still has Minerva NP electrolytic capacitors those have to go their ESRs will be sky-high. The best replacement for the Minervas is the Mundorf E-Cap plain. I use this cap in all of my Wharfedales it preserves the original sound, and the price is right too. The problem you have with Wharfedale is they were always making changes. All three of the inductors are Wharfedale. The wire-wound resistor is a later addition get rid of it. Here is a picture of a W60E crossover of about 1970 you can tell the age from the thumb cap nuts on the speaker posts later crossovers used open top thumb nuts. . Put a watch on eBay for a set of W60E crossovers they come up quite often and are reasonably priced. The layout of the crossover is the same on the W35, and W45.
Thank you infullview for all your help!
I hope it will improve bass. Other problem can be that rubber woofer surrounds are kind of stiff. I read it can contribute to lack of bass too. Unfortunately, I can't find rubber or foam replacement for Wharfedale W60 woofers.
Just check Parts Express - they have only 5% - is it OK?
3.3 Ohm 10W Resistor Wire Wound 5% Tolerance
Get a bottle of Sonax Rubber Protectant. This is used by several high-end speaker companies. They treat the surrounds on speakers systems that are returned to them for service. Again put a watch on eBay woofers for the W60E turn up frequently.
Sonax 03401000 Rubber Protectant GummiPfleger, 3.38 fl. oz. , black https://a.co/d/7mFxowK
Thank you Transmaster!
I can't see if your crossover has 3.3 Ohm resister on mid range?
Will order Sonax and let you know how it works.
Really? Ya, I guess if that's what they have then go with it. How stiff? The speaker may feel stiff to push, but the rubber should be supple enough to push up a section from behind without creasing or cracking the rubber roll.
Transmaster posted pics of 1970 crossovers. Wharfedale changed them a lot in 1972. Yours have the 4 mH inductor in series to the woofer, a 1.25 mH (low frequency shunt) for the mid, and .3 mH (low frequency shunt) for the tweeter which is the same as the schematic I pointed you to.
Thanks for the info, it is so hard to pin things down with Wharfedale. I have 2 sets of crossovers for the W45, one has 3 capacitors, and the newer version has just 2, This change came with a change from round magnet Wharfedale woofer to a Wharfedale with a square magnet.
Ordered 3.3 Ohm resistor, tomorrow should be here. Will re-solder crossover and try it. Will post results.
Did you get a noninductive resistor? I use Mills' noninductive resistors in 5-watt capacity. This seems very high but what you are doing is reducing the operating temperature of this resistor, even 10 watts is OK.
At Sonic Craft you can get the Mundorf E-Cap Plain.
https://www.soniccraft.com/product_...p-556?osCsid=77eb994ffe482efb9fb3b145334d2927
I sorry guys, it will sound dumb, but I have more question.
On your, infullview, crossover schematic, you have all drivers at 6 Ohm.
I just measured mine and I have numbers all over: woofer - 5.6, mid - 6.7, tweeter - 3.8.
Took them from cabinet and more mystery. Mid is not even Wharfedale but BIC 6178, tweeter is original - but 4 Ohm.
Now is question: do I need to change anything in crossover to accommodate?
For 3.3 - I got this one. Is it no-good?
3.3 ohm 10 watt wirewound resistor with 5% tolerance. Sold individually.
Key Features
  • Exceptionally small, sturdy, and reliable
  • Ceramic flame retardant package
  • Sealed with a special quartz mixed sand cement
  • Excellent moisture resistance
  • High temperature stability
  • 5% tolerance
  • Temperature Range: -55°C ~ +155°C
