Wharfedale Owners Thread
I sorry guys, it will sound dumb, but I have more question.
On your, infullview, crossover schematic, you have all drivers at 6 Ohm.
I just measured mine and I have numbers all over: woofer - 5.6, mid - 6.7, tweeter - 3.8.
Took them from cabinet and more mystery. Mid is not even Wharfedale but BIC 6178, tweeter is original - but 4 Ohm.
Now is question: do I need to change anything in crossover to accommodate?
For 3.3 - I got this one. Is it no-good?
3.3 Ohm 10W Resistor Wire Wound 5% Tolerance
3.3 ohm 10 watt wirewound resistor with 5% tolerance. Sold individually.
Key Features
  • Exceptionally small, sturdy, and reliable
  • Ceramic flame retardant package
  • Sealed with a special quartz mixed sand cement
  • Excellent moisture resistance
  • High temperature stability
  • 5% tolerance
  • Temperature Range: -55°C ~ +155°C
No problem and all your dc speaker readings are fine. 6 Ohms is an aggregate measure. 4 Ohms is perfect for the tweeter. Your resister will work fine even if inductive because it’s on the mid range and well below any frequencies the resister would affect.
Forgot to mention that BIC owned Wharfedale so don’t worry.
The W60E is one of the American Wharfedale’s. There is only hints these American assembled speakers existed. The W25, W35, W45, the W70, or the W80A Veriflex have no British named equivalent and are not mentioned in the book, A Pair of Wharfedales: by Prof. David Briggs. The W60, I think, was the Denton in the UK.
A Pair of Wharfedales has a detailed list of Wharfedale speakers. I was hoping to find more info on my Wharfdales, there is nothing.
Guys, you are great!
Crossover came very good and I treated rubber with Sonex. Sounds and looks amazing!
Can't thank you enough!
Best!
Did you wire tie the resistor to the cap’s? If so you need to separate it, and position it away from the caps. I learned the hard way the 5 Watt Mills resistors on my Polk Monitor 10B’s melted their way into the caps they were resting against.
Hi guys.
So I'm currently restoring a pair of the original Meltons.The crossover point is 1.5khz and the original cap is a 6uf.
Can i replace the original with a 6.8uf cap?
I've read other posts regarding the super lintons (which ive refurbished) stating replacing an 8.2uf cap with a 6.8uf would raise the crossover from 1.4khz to 1.5khz.
My plan is to replace the 6uf in the meltons with a 6.8uf on the tweeter along with a 22ohm resistor aswell as adding a 22uf on the bass driver...
Or is it best to not add the 22uf on the bass driver if i use a 22ohm resistor in the crossover.
Ive spent many hours looking at different wharfedale crossovers.
Looking at the linton 2 crossover it has a 10uf on the treble and a 25uf on the bass and no resistor.
Hello fellow Wharfedalers!
Over the last two or so years I have gone from complete novice to fairly well informed on the subject of vintage Wharfedales, that is the UK versions at least. I must admit to still being confused by the myriad of US models and how they relate to UK variants. It is interesting that the Wxx line with it’s suffix B, C, D etc does help when identifying variants, the UK never seems to have benefitted from that. My love began with the purchase of a pair of W2 Dovedales. (I have several now, all different). From this point on, I’m going to start referring to the different models with suffix’s too, so these, as far as I can tell, would be W2 Dovedale B’s.
I know there is a bit of supposition going on here, and that story of the fire which destroyed all the records at the factory is well known, but I believe the first W2’s were ported, (mine are ser no 8938, dated 1965) with a tygan covered baffle surrounded by a silk rope trim. The fronts were not removable. Cabinets are solid ply, veneered of course. The drivers are the iconic cast alloy framed alnico 12” units (polystyrene filled flat cone in this one, mesh roll surround) and a super 5 (5”) unit. The crossovers in all these early models of course are all simple, in this one it’s a huge tin box 10uF cap and 2.5mH inductor coil (measured). The cap incidentally is still within 5% tolerance after all these years. As to the sound, well… I can only imagine they must have amazed folk in 1965). However they lack the bass extension of a few years later.
Next in line and my first purchase, are nominated as W2/Dovedales, the first to have the newer, floating look fronts with silver trim surround. On these first updated versions (which I am going to call W2B’s unless anyone knows different) are still ported, the fronts are not detachable, but they look identical to the later ones with ‘pinned on’ fronts. They have the ser no. 5218 so clearly not contiguous with early models. The cloth, Tygan still, is wrapped over the baffle and screwed into the cabinet from the inside. The drivers in these are ceramic 12” round magnets with rubber roll surrounds (no poly filled cone here), with a 5” ceramic tweeter which still looks identical to the super 5 but has no identifying labels. The crossover consists of an 8.2 uF cap and 4mH inductor. It was these that began my love affair with Dovedales. The whole is so much more than the sum of its parts. Presentation is incredibly dynamic, fantastic mids and highs (though of course lacking any super high freqs, but unless you are 6 or a dog, you wouldn’t know). But it is the glorious acoustic quality to the bass these emit that makes them really special. It is not massively in-your-face, but resonant and physical (like a double bass being bowed). My hunch is that you can’t get that particular quality from an unported design, due to the difference in roll-off at the very low end.
Based on that experience I bought another identical looking pair, but I was disappointed to find they did not sound the same. The bass was good, very good in fact, but not as rewarding as my earlier models. On closer inspection they had the same cabinet, crossover and tweet, the 12” unit looked the same, still rubber roll, still cast allow frame, except it has a square magnet. And the baffles had removable fronts. For this reason I am going to call them W2C’s. I checked the compliance of the woofers, exactly the same. I measured the crossover components and the driver coils, exactly the same. The only difference was the square magnet. Could that really make such a difference and if so, why did Gilbert allow it? Perhaps he preferred it, I certainly didn’t.
So I went in search of another pair of W2B’s, (yes I know it’s entitled of me to come up with a naming strategy of my own but bear with me, I’m open to suggestions!). I eventually found a pair, and they confirmed my suspicions, they sounded wonderful and exactly the same, same acoustic bass quality.
For info, I have not yet encountered any vintage Wharfedale drivers with any detrimental hardening of the rubber or stiffness in compliance, they seem to age very well and if anything, loosen up with years of use. I have noticed that some of the driver units in the ‘kit form’ speakers known as Unit 3, Unit 4 etc had much smaller magnet arrays, and a warning that they should ONLY be used in sealed cabinets of specific dimensions, presumably they do require the dampening effect of a sealed enclosure. Not sure if these were also used in later production models like the Melton, but every picture I’ve seen of any later Dovedale’s seem to use the large magnet array used in the early ones.
I have since listened to some later models, the closed cab, unported, infinite baffle designs with three drivers, and for me they are a step backwards. Of course, they will handle a lot more power, but they sound strangled and boxy in comparison.
This leads me to a few ponderances, and I really appreciate any comments.
1. Why did Wharfedale change from ported to infinite baffle design? Perhaps it was necessary to get the power handling at the time, if driver design couldn’t damp the larger transients?
2. Has anyone else compared different models like this, and what did you find?
3. Does anyone appreciate the bass response I am talking about, or is it just me?
4. Most importantly to me, does anyone know if there was a change in the bass drivers internal design when the change was made to closed instead of vented cabinet. The reason I ask this is because it has always been a want of mine to try a 15” bass driver, and I have just bought a pair of Rosedale’s which haven’t arrived yet. I bought these on a whim, have very little info on them, but I believe they are slightly later and I don’t expect they will be ported. I would like to experiment with porting to see what happens (don’t worry, I’ll make sure anything I do is reversable) but is it ok to use the 15” driver designed for sealed cabs in a ported design? I know some early 15” cabs in the U.S. were ported. It is interesting that all the drivers in the ported and unported W2’s and Dovedale’s all have the rubber roll and appear the same, even though they were used in both ported and unported designs. Is there a difference I have missed?
My investigations continue, but if anyone has any comments or info on any of my pondering I would be very interested in them. Sorry for the long post.
This book does a good job of covering the “English” Whatedales. The whole back section lists speaker models and drivers. Sadly it has little to say about the American Wharfedales.
In the States, during the 1960s the absolute darling of the Audio press was Acoustic Research. So AR had a huge influence on speaker design over here. The Acoustic suspended patients did not run out until the late 1960s. The expiration of these patients gave rise tio the American Wharfedale the D and E models.
Gilbert Briggs Was a prolific author a great insight can be gained into his design philosophy from his books and articles.
Interesting pair of Wharfedales posted recently local!
Just browsing the local online sales and look what came up! I've never seen a set of speakers like this before! Capturing pictures for posterity.
Taken from the ad:
These circa 1960s Wharfedale speakers mounted in mid century modern cabinets are in good working condition. Wharfedale Super 3 "For treble only" drivers in satellite stands and cabinets with W10/FSB - 10" drivers. Speakers tested and are working. All 4 are in excellent shape and just need new foam surrounds. Crossovers mounted on bottom of cabinets. The wood cabinets are heavy and very solid. Veneer has lifted in a few small spots.
View attachment 2669096 View attachment 2669098
Taken from the ad:
Oh, Holy CHRIST - Can only hope they sound as good as they look.
In the 1950s and 1960s Wharfedale had an extensive catalog of drivers and at least 2 crossovers. Gilbert Briggs published a number of books on speaker design. I am not at all surprised that you are see custom-built Wharfedale in the UK.
This set is here in Canada. I came across these on FBM, and the owner is asking 2 bills for them. They are stunning, aren't they? And I like 10 inch woofers. I would be single again if I brought these home, and I don't want to be single. ;)
Seeing your post with that image triggered a memory when I went to the library, browsed through a few books, and ended up with a really good book. Good enough that I designed and built a pair of transmission line speakers that sounded good! All at the age of 14.
