braminator
Member
Just curious to why the protection lights come on at certain volumes. Is the speaker causing it or does the amp not have enough power to drive the speaker?:scratch2:
Yep. It means that your amp is running out of steam at high volume.Either turn it down or buy a more powerful amp.
The volume is louder then I could stand in the room.
question for jdandy again... so if I get my MC 2200 and/or MC 2205 with Power Guard really cranking and the red lights start to flash, there is no danger of clipping?
Yep.This might help: http://www.roger-russell.com/mcintosh2.htm#powerguard
The Power Guard circuitry is doing its job to protect your amp and speakers (not your ears :nerd: ). That said (and since I'm not one to push the equipment REAL hard), if I found that my Power Guard lights spent a great deal of time flashing red, I might either look into a more powerful amp or more efficient speakers.
Your speakers are not at risk of damage from the amp clipping, which is a very common cause of speaker damage. But you could still damage the speakers by over powering them. If you give any speaker enough power it will be damaged.okay jdandy, so just to confirm... when the meters on my MC 2205 are dancing to the right, and the red power guard lights start to flash, I am not putting the amp or speakers at risk?
Is there any danger when the red lights are flashing for a prolonged period of time? (other than to my hearing!) or are the amp and speakers fully protected?
