That's a pair of L60Ts, all right. Unfortunately, with non-original woofers. The original woofer should be a cast-frame 8"... that's a cheap stamped-frame woofer in the OP picture...
These speakers should have JBL model 116H-1 or 116H-2 woofers in them... quite good woofers.
Regards,
Gordon.
good call , those look like radio shack woofers to me. the refoam on
mine was a pain . i had to trim a 1/2" or so and splice the mat foams.
still, not the worst speaker i own.
If all they need is the proper woofer(s), those pop up on eBay quite often. In fact, just about anything you need to fix a member of the L-series is found on the net without too much trouble, and prices are pretty reasonable to.
If those L60Ts are in otherwise good shape, and the price is right, I would pick them up, and fix whatever is wrong with them.
I've owned a pair of L60Ts since new in 1988 (cost me $800 back then), and am very fond of them.
Normally I would agree, but the reality is these often sell in the $50 range complete needing nothing but re-surround. Even the larger, much more highly regarded L80T often doesn't crack the century mark and you will always find the L60T taking a back-seat to nearly anything else in that JBL L-T family, including the smaller L20T. If you want L60Ts, just buy a complete pair and don't bother with these. If you want to make money off them, then research what the tweeters alone are worth and make your own decision to part, or not. Waiting for woofers to show up is a fools game on this pair, IMNSHO. :thumbsdn:I would also think twice before passing. As you know, AK is a great resource and I would bet that if you hang out here long enough and search your local CL and auction sites, a pair of woofers will turn up, priced right.
Wouldn't have been a pain if you didn't cheap out on the foam surrounds rather than getting exact replacements :nono:
