I want to buy a record clamp for flattening slightly warped records. Which one do you recommend and why? I will use it with Denon, Thorens, Technics & Pioneers TT's.
Thanks, CB
Thanks, CB
Another vote here for the Michell. They come up on ebay regularly, sometimes for cheap. Be sure it comes with the felt donut though!
Might affect the main bearing in the long term, though.I Use a Michell on my Thorens TT. It's lite enough does not affect the suspension.
Thanks Guys! The Mitchell sounds like the way to go. :thmbsp:
Ditto on the the Michell, I use one on the Rega.
Dave/ChairSpud
The problem isn't the suspension, but the main bearing. 2.4 oz is effectively a lot more as it isn't distributed evenly by the platter but weighs directly on the main bearing, but, having thought about it, given the Thorens uses a ball bearing the extra weight is distributed better than, for example, on an LP12 so it shouldn't give any problems.
I do have a question, though. Given the Thorens, as with many belt drives, is ideally turned on at the start of a session and off at the end, surely it is difficult to put the clamp on while a record is spinning?
You can guess I've never even seen a clamp, can't you?
