vinylkid58
Have you been using the Fonkens you had at Dave's a couple of years back?
Not for a while. I'm less inclined to change speakers, as the Super Pencils are kinda big and heavy. They sound pretty good too.:yes:
jeff
Here's my DIY fullrange speakers. Bi-amped with 2a3 and 300b amps. Goodmans Axiom 80 at fullrange, Axiom 22 at fullrange and Fostex 925 X'over at 14KHz.
http://s1151.beta.photobucket.com/u...pg.html?&_suid=135417257347009631845066860509
These full range 12 inch Eminence Betas over H-frame Alphas are currently my best all around effort. I use a Bottlehead 2a3 for the 98 db Betas, a Topping T-amp for the super tweeters and Yung class D plate amps on the Alphas. Instead of passives I use an electronic crossover and there's no lack of bass with the H-frames.
You raise a very legitimate concern. There will be significant combing happening in the frequency response, but I don't think most people are to sensitive to those effects.
Beautiful, but how do you classify that as full-range with a single driver?
Yes the OB's are 3 way but wouldn't my single driver Frugal Horns with a sub be a 2 way?
Yes.
I think the intent of this discussion was more towards that single driver no XO point source type designs of which many are shown as an example here. Once you add a XO (only needed for more drivers) then it is no longer a single driver full range setup.
Yes. [/B]
