Poultrygeist
Lunatic Member
I plan on carving some phase plugs for the Betsy's from wine bottle corks. That should help smooth out the top end and reduce beaming.
Here's another picture of the Betsy full range single driver in the folding wing OB. I found some inexpensive piano hinges at Big Lots and they did a good job of sealing the back wave. I understand the original Betsy and Betsy K drivers used exotic banana fiber cones.
The Miniwatt SET ( tiny silver amp ) is shown driving the Betsy's.
Here's a set of MLTL's with the 110.00 pr. betsy k drivers. Using them with a RH-84 amp.
It cost me about 325.00 for all the materials to build. Sound sweet. http://audiokarma.org/forums/showthread.php?t=470803
MK
Yes.
I think the intent of this discussion was more towards that single driver no XO point source type designs of which many are shown as an example here. Once you add a XO (only needed for more drivers) then it is no longer a single driver full range setup.
From the OP...
"I've been contemplating building a pair of "full range" speakers, using a high-quality 6" or 8" driver in a transmission line or ported enclosure. I'm looking for a tall-slender-deep profile. Considering Fostex, Fountek, or Seas for a driver. I think it would be an interesting study to see how the lack of a crossover influences the sound."
baco99, if you do a search on "H-frame dipole subwoofers" you'll get some good information. In order for dipole subs to reinforce bass well, tend to need very large baffles and/or EQ. The h-frame design is a compact way to fool the woofer into thinking it's in a bigger baffle than it really is. Couple it with a very high Q driver and you can get pretty nice bass from a compact space with the benefits that go along with dipole operation.
Pioneer PE12. Run full range but it has a super tweeter, Very nice midrange out of that little bugger.
I am also a lover of the Radio Shack FR. These were given to me by ejfud. Built to the Hawaii plans available online. They await a set of phase plugs from Planet 10.
