Bill Haywood
Member
You are stuck with what you get unless you use a equalizer. The designer decides what he thinks sounds best and that’s it. I like the option to make changes. What do you guys think?
I know what I like to hear and you guys too and I like the option of tone control for me. The guys that design this stuff are using 20,000 dollar speakers 5 to 10 thousand amps and have specially designed listening rooms.
You are for sure right it is easier to build without the tone controls and cheaper too. But more expensive.Well its a lot easier to build a balanced pre-amp with out tone controls. I don't even think Accuphase builds a totally balanced EQ. There's are digital. A balanced pre-amp requires easily twice as many parts as a conventional pre-amp. I have never understood folks wanting a pre-amp with out tone controls. 99% of LP's need help. Oh there are a few direct to disc, that don't need help, and maybe a few Commands, Telarc, Reference recording, and Mobile FIDELITY, but others need help. Especially if you have an austere cartridge or one at the opposite end of the scale. As far as CD's are concerned. At least they are pretty consistent and why I won't even consider Deutch Gramophone anymore. Here again having an outstanding disc player/decoder really helps. Streaming is so compromised I can't get enthused about it. Once a month or so I'll try some thing new. I am not into current POP except for a little CW and R&B so most of the services just offer noise as far as I am concerned. But even with the classical sites I am having trouble with the mics they choose and where they place them. I don't want to be standing on the podium with a baton and the use of solo mics and sweeteners is just too prominent today. I don't like hearing spit sloshing around in people mouths as they sing. Same goes for solo instruments with mics attached to the bells. The only choices we have to calm things down a bit is tone controls, unless you want to add ambience to a stereo recording with your HT processor . I do that too, some times. Modern recordings have very little dynamic range in the pop venue, so I still keep my 3 BX. I can see the audiophiles shaking in their boots at the thought. Go to a live concert of any venue and get a sound level meter app for your iPhone 10X or Sansui and learn about live sound. Take away the amplification and just listen to acoustical instruments. You might learn something. You will find you do need tone controls. I prefer Graphic and 5 to 12 is. nice number. Then there are the guys with passive pre-amps with just a switch or two and a couple of pots. People think they sound great, if they only knew? Insert an L-pad to T-pad between your direct coupled amp and your loud speaker and listen to the difference, same deal. Yes more exaggerated as a speakers impedance isn't as constant, but you'll get the idea.
You are correct I usually pretty much leave my bass wide open but mainly I have to adjust my treble. Without the control my opinion some songs are not worth listening too. That’s the problem with my tube preamp no control and it is so frustrating. So I always go back to my trusty Dynaco. I know that a lot of the problem is guaility of recordings so that’s when you need the option.Well its a lot easier to build a balanced pre-amp with out tone controls. I don't even think Accuphase builds a totally balanced EQ. There's are digital. A balanced pre-amp requires easily twice as many parts as a conventional pre-amp. I have never understood folks wanting a pre-amp with out tone controls. 99% of LP's need help. Oh there are a few direct to disc, that don't need help, and maybe a few Commands, Telarc, Reference recording, and Mobile FIDELITY, but others need help. Especially if you have an austere cartridge or one at the opposite end of the scale. As far as CD's are concerned. At least they are pretty consistent and why I won't even consider Deutch Gramophone anymore. Here again having an outstanding disc player/decoder really helps. Streaming is so compromised I can't get enthused about it. Once a month or so I'll try some thing new. I am not into current POP except for a little CW and R&B so most of the services just offer noise as far as I am concerned. But even with the classical sites I am having trouble with the mics they choose and where they place them. I don't want to be standing on the podium with a baton and the use of solo mics and sweeteners is just too prominent today. I don't like hearing spit sloshing around in people mouths as they sing. Same goes for solo instruments with mics attached to the bells. The only choices we have to calm things down a bit is tone controls, unless you want to add ambience to a stereo recording with your HT processor . I do that too, some times. Modern recordings have very little dynamic range in the pop venue, so I still keep my 3 BX. I can see the audiophiles shaking in their boots at the thought. Go to a live concert of any venue and get a sound level meter app for your iPhone 10X or Sansui and learn about live sound. Take away the amplification and just listen to acoustical instruments. You might learn something. You will find you do need tone controls. I prefer Graphic and 5 to 12 is. nice number. Then there are the guys with passive pre-amps with just a switch or two and a couple of pots. People think they sound great, if they only knew? Insert an L-pad to T-pad between your direct coupled amp and your loud speaker and listen to the difference, same deal. Yes more exaggerated as a speakers impedance isn't as constant, but you'll get the idea.
Sound to all of us is different what you think sounds fantastic might not sound so good to other people.Well its a lot easier to build a balanced pre-amp with out tone controls. I don't even think Accuphase builds a totally balanced EQ. There's are digital. A balanced pre-amp requires easily twice as many parts as a conventional pre-amp. I have never understood folks wanting a pre-amp with out tone controls. 99% of LP's need help. Oh there are a few direct to disc, that don't need help, and maybe a few Commands, Telarc, Reference recording, and Mobile FIDELITY, but others need help. Especially if you have an austere cartridge or one at the opposite end of the scale. As far as CD's are concerned. At least they are pretty consistent and why I won't even consider Deutch Gramophone anymore. Here again having an outstanding disc player/decoder really helps. Streaming is so compromised I can't get enthused about it. Once a month or so I'll try some thing new. I am not into current POP except for a little CW and R&B so most of the services just offer noise as far as I am concerned. But even with the classical sites I am having trouble with the mics they choose and where they place them. I don't want to be standing on the podium with a baton and the use of solo mics and sweeteners is just too prominent today. I don't like hearing spit sloshing around in people mouths as they sing. Same goes for solo instruments with mics attached to the bells. The only choices we have to calm things down a bit is tone controls, unless you want to add ambience to a stereo recording with your HT processor . I do that too, some times. Modern recordings have very little dynamic range in the pop venue, so I still keep my 3 BX. I can see the audiophiles shaking in their boots at the thought. Go to a live concert of any venue and get a sound level meter app for your iPhone 10X or Sansui and learn about live sound. Take away the amplification and just listen to acoustical instruments. You might learn something. You will find you do need tone controls. I prefer Graphic and 5 to 12 is. nice number. Then there are the guys with passive pre-amps with just a switch or two and a couple of pots. People think they sound great, if they only knew? Insert an L-pad to T-pad between your direct coupled amp and your loud speaker and listen to the difference, same deal. Yes more exaggerated as a speakers impedance isn't as constant, but you'll get the idea.
Do the tone control guys adjust them for every song/album?![]()
It has nothing to do with cheaper and all to do with SQ and S/N ratio.You are for sure right it is easier to build without the tone controls and cheaper too. But more expensive.
Every title,mastering and recording is different, are you going to adjust for every title you put on?I know that a lot of the problem is quaility of recordings so that’s when you need the option.
All systems and the rooms they're in are different also.Sound to all of us is different what you think sounds fantastic might not sound so good to other people.
