signal-dude
Just one good watt.......
You can try some nice polypropylenes to see what you think -- I tried it with some Old Advents and the top sounded too hot.[/QUOTE]
Greetings All, I just finished a recap and recoil? of a pair of 1975 Large Advent Utility's. For some background they sounded OK at low watt levels, 1/2 watt or so but crank them up higher and the music blended into into a mush is my best description.Also what I would agree with as a too hot mid range.
So after researching all about cap soakage,leakage, DF,DA,ESR, ESL, Polar, Non Polar, Mylar,Electrolytic,Polypropylene,
Teflon,Metal Polyprop,PIO, Film and foil, Solens, Mundorfs, Sonicraft, Auricaps, house brands, Jantzens, Kimbers, and all that I decided on using Solen MPP's from PE.
And also changing out the ferrite core inductor in series with the woofer with an air coil of the same value and DCR as the original. Also from PE. And what I also did to cool off the hot mids was to change the 3 ohm sand resistor in series with the tweeter with a 5 ohm Mills resistor that according to my calculations should lower the voltage to the tweeter by 2 db or so.
Well, after the parts swap to say the change was startling would be an understatement. No more mush at higher levels and the mids were much more balanced to the low end. I heard instruments that I had no idea were there.
You won't hear any Audiophool drivel from me about lifting veils and such but I just heard good clear music coming out of my vintage Advent's. My guess is that the old Electrolytics had some awful DA in the 10 percent range or more. Probably what I described as mushy sound as the cause. They checked out at the labeled capacitance but thats as good as I can test them.
So the combo of better caps, reduced drive to the tweets and an air core woof inductor made a substantial increase in my enjoyment of these old gals. As many wiser heads have said here and elsewhere, get rid of them Electros and slap in some good caps of your favorite flavor. My choice may not be your choice so YMMV.
And as a final comment I would have to say the different parts did not change the voicing of the Advents just cleared it throat, sorry....
Marcus
Marcus
