justin_r_23
Aha! There's that Linkplay connection!
So far I'm really impressed with the Wiim ProPlus capabilities, especially their continuous firmware upgrade process to add / improve features at no additional cost.Here's an example of a DIY capsule (in stock at digi-key -
DIY capsule
Thanks for the tip! The WiiM Ultra is also on sale for $263.20 (reg. price $329).FYI, If you are a Prime member, all 3 of the Wiim streamers are on sale at Amazon today (7/10/25) with about 20% discount. The Pro Plus is ~$175, the Pro is ~$120, and mini ~$79
I just had a small problem that reminds me about how many times I've had such problems on the last few years. I was trying to play some music on my WPP, and the Tidal app in my phone couldn't see the player. But the LMS server could see it just fine. After about 1/2 hour of screwing around trying to figure out if the problem was in the WPP, the Wiim home app, the Tidal app, etc., I discovered that my phone wanted an android update. Once I did the update, the WPP reappeared.
I love my WPP and my Squeezebox Touch, but stuff like this happens more often than it should. It seems like every time other time I want to listen to music I have to screw around to get something working properly before I can hear anything. Now I always have a little feeling of dread every time I want to listen to music. Will it work this time, or will I be chasing problems again? It's especially annoying if I have a visitor who wants to hear my wonderful stereo system. It will always fail under those circumstances.
Sometimes I use an android tablet to control the WPP, sometimes my phone, whichever is handiest at the moment. If I was last using the phone, and now want to use the tablet, I have to restart the Tidal app on the tablet to get it to take control of the WPP.
And that is why CDs are coming back...
I've recently encountered an issue with my WiiM Pro, where it "skips" a half second or so of a song, approximately every 2-3 minutes, using Apple Airplay via my iPhone 13Pro and my MacBook Pro over airplay. This is slightly different from a similar issue I had with it and Tidal and I've recently upgraded my wifi from a 10-11 y.o. Apple Airport Extreme to a TP-Link Decco 6e mesh router that's 6 feet from the WiiM on a separate electrical circuit, that I thought solved the problem. This has been a recent occurrence that I've noticed in the past week. Next steps are to use my MBP, hard wired via USB into my Schiit Bifrost 2/64 DAC as a control and compare that to both the WiiM and my Apple TV, both via airplay.
Yes, this is simpler and usually more reliable.run an Ethernet cable from the WiiM to the nearest Deco node Ethernet port, at least temporarily as a test?
I cant help with your problem.Which how does that happen to something thta's just sitting on a shelf for a year and half-ish?
I assume you tried a different 5V power supply? I've had a number of electronic things go flaky, but not totally die, and replacing the outboard wall wart supply fixed them.
That includes routers, TIVO devices, etc.
But also had a few Chinese made electronic things just totally died - a Bluetooth audio transceiver, small $50 DVD player, and most recently a Ninja blast smoothie blender. All less than a year old. Amazon reviews also show this same trend - looking at negative reviews for some devices, it seems like some small % die at the 6-12 month mark. Al these cost less than $50. so losing them was disappointing and confounding, but not a disaster financially.
The newer stuff is all SMD inside, so very difficult to even look for or replace obvious things like big caps that went bad. I fix a lot of things, but the root cause of all these failures was unknown. Works one day, does not the next.
Funny thing is, I own 3 Slim Devices streamers bought over 20 years ago, and they have been plugged in and used continuously all that time. All have bright displays and work fine to this day. They all have large oversized linear, well filtered power supplies. Not sure if that has anything to do with it, but it can't hurt.
I have 2 Wiim devices and don't use the small supplied 5V 2A power supply with either. I use larger units from Anker, and will be adding DIY Audio power supply filters to each.
