Hey Dobyblue,
As soon as the first side is dry, I apply side 2 without removing the dried first side. (No sense having a clean side exposed with attendant static charge issues - until you're ready to put it in a sleeve....)
P.S. - Just love the stacking, sxty8goats.
sxty8,
With regards to your static problem at home try wearing different shoes or bare feet.The static charge builds-up in your body.....
I found that static can be reduced if you put the records on some dryer sheets (Bounce, or equivalent) while peeling.
Thanks, I'm barefoot most of the time at home. My static problem is mainly with the build up caused by peeling glue.
Years of detailing cars has pretty much sworn me off of fabric softener of any kind. They tend to leave a waxy film on the fibers of your cloths and drying towels. These then streak and hold dirt in ways that are unkind to paint finishes. Vinyl isn't much different than a clear coat on a car... Which actually gives me another idea.
I use a detailing spray, Zaino Z6, on my car/bike. It leaves a nice shine and a slight coat that repels water and dust quite nicely. It is water based, possibly a silicone film product. The dust protection has to be some level of anti-stat. I may have to do something silly and try it on a test album.
I'd be very wary of applying any kind of spray to the record and letting it dry, other than something specifically designed and proven for use on LPs, like the Last products. I'd be worried about gunking up my stylus. If you try it, keep an eye on your stylus for accumulation.
I think its funny how no matter how many pages there are in this thread and how many times people say 'this is amazing' people still are like 'I have a worthless throw-away firestone christmas record that I'm going to try it on.'
I can't blame them I did the same thing!
Anyway, I have found that thinning the glue w/ water or isopropyl makes it too easy to tear, but I found the perfect alternative.
Aleene's + Elmer's Clear School Gel = Vinyl Cleaning Heaven
For those who haven't tried either, Aleene's is a very flexible rubbery strong glue that peels perfectly, but is thick and takes a while to dry and spread. Elmer's Clear School Gel is a very thin glue (it looks like thick water when you tip the bottle) that can be used on its own if spread properly (I found using a paintbrush works quickly but spreads the gel too thinly in only one coat to peel properly) and it dries very fast ~1-2 hrs.
However I found that if you mix the 2 you can use a paintbrush to paint it on and it dries very quickly and peels perfect! :thmbsp:
I.d be shocked to see any residue left from the product. It is water thin to begin with. I've used it on just about every surface of my car, including glass, plastic and rubber with no evidence of build up.
IMO, if it contains anything that repels water (like silicone) it will, by definition, be leaving a coating of *stuff* on the grooves. It's highly likely that that "stuff" will then be transferred to and build up upon the stylus. Even if the stuff is microscopically thin on the grooves, think of the total surface area of the grooves (probably over a hundred square inches) compared to the surface area of the stylus (maybe a few millionths of a square inch, if my calculations are correct) and you can see how even a tiny amount of contamination in the grooves is cause for concern.
GORILLA wood glue works great. Titebond original, I guess bites. Titebond is way too brittle to peel, while the Gorilla Wood Glue, not the poly stuff, peels real nice. I used the Gorilla to get the Titebond off.
