Yamaha C-2 component leak
index.php
C227/228
After putting the high power magnifying glass on it: Maybe that is a 3 and not an M, crazy font. I also noticed a couple more ceramic caps with the black dot, They state the value followed by "J"?
My first question is why are the voltages so high? Values specified to be in the 30V range are measured in the 50V range.
The voltage off of the transformer are specified to be 33VAC with 120VAC at the Primary
They measure as 41VAC
Also the power switch doesn't change power to the PS Board (On/Off). It is always on. The only thing the power switch changes is the power light On/Off.
TR401 and 402 are JFET,s Drain,source and gate.. Not emitter,base and collector.
I guess you have never seen these black topped ceramic caps in any other Yamaha equipment?
Probably have . But I don't pay them much attention if there is nothing wrong with them. If it ain't broke,don't fix it. Come to think of it. The only ceramic cap I have ever replaced was due to the glue corrosion of the leads.
Looks like the power switch never did any function:
