On the subject of LED's, have any of you come up with a foolproof way of getting the LED's to look like an incandescent? I've tried a few times with various equipment and although the illumination level is usually adequate, the color temp and unevenness of the light dispersion is always a turn off for me. Always end up using the proper lamps, which while they look correct and great, do not always last that long. I do use lamps from reputable sources that usually have lifespans of anywhere from 5-16,000 hours at rated voltage, but with some lamps you gotta use what you can find. My Denon POA-1500 power amp is a prime example. Even the original, correct lamps only lasted a couple thousand hours and Denon even put out a service kit to increase their endurance. This would be a natural for LED conversion and although I have seen many examples of it done, none of them look correct. Am I being too unrealistic or is there a tried and true solution?
